Hi all,
I need a bit of guidance on a load sharing circuit to power my Cortex M0 PCB.
I am using a 110mAh 3.7V LiPo battery as my main source as this project is Wearable based, however i also wish to charge it from USB , i've done this succesfully using the MCP73831, however i want to be able to detect when USB is plugged in so it automatically charges and sources from USB and when it is not it simply uses the battery, I've had to manually use an SPDT switch to toggle this. I figured a MOSFET would be best for this, a circuit is shown below:
With the P-MOST turning off when 5V is applied this allows the battery to charge and the load to be sourced from USB.
With P-MOST on when 5V removed, the battery then sources to the load.
The issue i have with this circuit is that from 'load' i also have/need a 3.3V LDO to power my MCU, in worst case scenarios and with rdsON of the FET the voltage from 'load' could drop below 3.3 nullifying the circuit.
What would be the best way to have this load sharing that also allows me to use and LDO or similar to 3.3V?
Andrea
