Author Topic: logic ics for above 100 MHz operation  (Read 840 times)
Offline txx4488Topic starter
  • Country: in
« on: December 21, 2018, 02:21:38 pm »
which are logic ics for or above 100  MHz operation ?
Offline mvs
Re: logic ics for above 100 MHz operation
« Reply #1 on: December 21, 2018, 03:06:38 pm »
Schottky-TTL logic (74AS, 74ALS, etc), emitter coupled logic (ECL, PECL, LVPECL, etc), some programmable logic (CPLD, FPGA) and application specific ICs may have propagation delay under 10ns...
« Last Edit: December 21, 2018, 03:18:58 pm by mvs »
Offline Benta
« Reply #2 on: December 21, 2018, 04:03:14 pm »
74ACxx powered at 5 V will run to 125 MHz (flip-flop clock speed).
Offline joeqsmith
« Reply #3 on: December 21, 2018, 09:49:16 pm »
I picked up one of those cheap Arty boards a while back and was able to clock it at 700MHz.
https://www.eevblog.com/forum/microcontrollers/typical-speed-of-fpgas/msg1282290/#msg1282290
Offline RoGeorge
« Reply #4 on: December 21, 2018, 09:59:02 pm »
Unless it's a very simple logic, logic IC's like the 7400 series are rarely used nowadays.
Instead of discreet 7400 type logic, nowadays FPGAs/CPLDs are used. and most of them (FPGAs/CPLDs) can do 100MHz or more.  Even more, there is a myriad of microcontrollers that can do logic operations in the 100s of MHz range.
What logic do you want to implement?  How complex it is?  What project do you had in mind while you were asking the question?
« Last Edit: December 21, 2018, 10:05:36 pm by RoGeorge »
