Author Topic: Looking for a cheap, low voltage, low power, 'rail-to-rail' op-amp/comparator  (Read 5139 times)
Offline leppieTopic starter
Hi
This has probably been asked several times. Sorry if so :)
I need an op-amp that can work as low as 1.8V supply voltage (3.3V max) that would output at least 0.7 x V_supply.
I have no idea really how to determine the output voltage from the datasheets unless they say rail-to-rail (I am probably overlooking something  :palm:) or state it like the LM358.
It needs to be a cheap and easy to get one (I really feel like ordering from RS, in South Africa, but will if I have to). Ideally in DIP for breadboarding.
Wont need to work at high speed, 100Hz-1kHz should be more than enough (I think...).
Any suggestions?
Thanks
leppie
Offline jmag999
Microchip makes many parts that would fit your requirements.  For example: MCP6241.
That looks a great fit, unfortunately only available from RS locally :(
Offline jmag999
There are many many models you could pick from.  What manufacturers are available locally to you?
RS has pretty much everything, but as we have no local 'counter' any more, shipping is $10 and up :(
I did manage to find a local place selling MCP6547 which looks like it will do the job. Only $1.50 too  :-+
They also have a MCP6002 in SOIC (need to look for those adapters I ordered years back...) for $0.50.
Thanks for the suggestions, it helped my pin point my search.
« Last Edit: July 24, 2014, 06:10:19 am by leppie »
Offline LukeW
MCP6001 is another possible candidate - very cheap, and rail to rail. But there are downsides of the limited 6v supply voltage and limited bandwidth.
Offline MrsR
Try LM393 or LT1017/8
I've a project nearly finished using the LM393 but needed a LT type to test in LTSPICE IV.
I would have to double check the  LT models but it's on of the first row in comparators in LTSPICE IV.
HOPE THAT'S OF HELP
Rachael :-+
Yeah, I have been testing on LTSpice and with a LM358 on breadboard.
It definitely seems I need a comparator and not an op-amp (but I might still need one for peak detection).
Found a nice app note from TI: Op Amp and Comparators – Don’t Confuse Them! http://nliebeaux.free.fr/ressources/aop_et_comp.pdf
Offline Zero999
  • 0999
Yes, the general advice is not to do that, although there are application notes on datasheets, showing op-amps used as comparators and vice-versa. A classic example is the voltage controlled oscillator which requires both a Schmitt trigger (ideally a comparator) and an integrator (ideally an op-amp) so it's very tempting to use an op-amp or comparator IC to perform both functions.
Half of an LM358 op-amp used as a Schmitt trigger, thus acting as a comparator:
http://www.ti.com/lit/ds/symlink/lm158-n.pdf
A quarter of an LM339 comparator used as an integrator, thus acting as an op-amp:
http://www.ti.com/lit/ds/symlink/lm339-n.pdf
The best way to build this circuit is to use an op-amp and a comparator IC.
