Author Topic: Looking for a Hakko FX-888/FX-888D  (Read 11787 times)
Offline birdieTopic starter
« on: July 23, 2013, 02:48:28 am »
Offline jmole
    • My Portfolio
Re: Looking for a Hakko FX-888/FX-888D
« Reply #1 on: July 23, 2013, 03:02:08 am »
First one you listed looks legit. Same box/accessories that I got from Amazon in the US. We ordered 3 or 4 for a lab course about a year ago. Good price on it too. Great iron.
I'd recommend the non digital version. I've found that unless you have a very high-end digital iron (like my personal favorite), it's much easier to manage one with a little turny dial.
Offline IanB
« Reply #2 on: July 23, 2013, 03:08:33 am »
The FX-888/888D costs $90-$110 in the US as the 120 V version. The 230 V version typically costs rather more than that. So if you see it listed at $80 it will be suspect. There are Chinese versions that look the same on the outside, but have different electronics on the inside.
Offline nukie
« Reply #3 on: July 23, 2013, 03:09:26 am »
Ask for the serial no. before you buy, if the seller is hesitant then avoid at all cost.
Offline nanofrog
« Reply #4 on: July 23, 2013, 04:18:00 am »
I'm with IanB on this. All of the links posted are from Chinese locations, and are highly suspect IMHO (proven that fakes exist, and would expect this to be more common for 220V variants, since US 120V vs. 220V versions for most of the planet differ substantially on price; figure ~ double US pricing from what I can tell on avg.).
For example, Element 14 has the following:
FX-888: http://au.element14.com/hakko/fx-888/soldering-station-fx-888/dp/1719021
FX-888D: http://au.element14.com/hakko/fx-888d/soldering-station-digital-70w/dp/2280753
Hopefully, there are others who could point you to lower prices for Australia (Element 14 has stock on both).
Offline Guppzor
« Reply #5 on: July 23, 2013, 04:54:20 am »
I purchased my Hakko FX-888 a year or so ago and at the time I was tossing up between buying from eBay or some other overseas source for about the same price as the listing you linked to. At the end of the day I went with ordering on from element14 ($180ish including shipping at the time IIRC) because I could not be certain I was going to get the real deal from overseas and if I did have a problem I would end up spending the same if not more. Plus it was here the next day...  :P
Offline johnboxall
  • You do nothing, you get nothing.
    • Books, services and more:
« Reply #6 on: July 23, 2013, 07:41:41 am »
Absolutely.  Also try Mektronics.
Offline shailesh3t
  • Country: mu
« Reply #7 on: July 23, 2013, 08:50:27 am »
i bought mine from adafruit n its seems to be a good one
Offline Guppzor
« Reply #8 on: July 23, 2013, 10:45:41 pm »
+1 Only reason I didn't get it from them was that I needed some other gear that element14 had that Mektronics did not.
« Reply #9 on: July 24, 2013, 02:27:37 am »
I decided to buy the Deal Extreme one... from reports it sounds like its genuine... and if it is fake its a really good one that people haven't had trouble with...
hopefully I've made the right decision...
Offline nukie
« Reply #10 on: July 25, 2013, 01:26:39 pm »
If you don't have a real one to compare side by side its really hard to judge. The only part thats most obvious is the grip. It is very firm, high density foam material.
Offline ddavidebor
    • Smartbox AT
« Reply #11 on: July 25, 2013, 01:49:09 pm »
If it's not an hakko and it's wrote hakko they will give you some money back.
David - Professional Engineer - Medical Devices and Tablet Computers at Smartbox AT
Side businesses: Altium Industry Expert writer, http://fermium.ltd.uk (Scientific Equiment), http://chinesecleavers.co.uk (Cutlery),
« Reply #12 on: July 29, 2013, 10:19:36 am »
I ended up cancelling my order from DX this afternoon... the order hadn't progressed at all...
So I'm back to square one... now to decide where to get one... or maybe similar alternative suitable soldering station...?
Offline johnboxall
« Reply #13 on: July 29, 2013, 10:54:34 am »
If you're handy to one of their stores, check out the Altronics Micron stations, for example:
http://www.altronics.com.au/index.asp?area=item&id=T2416
Some Dick Smith stores still have the T2200 station:
http://www.dicksmith.com.au/tools-hobbyist/temperature-controlled-soldering-station-dsau-t2200
it's an old design, but still going strong after almost 30 years.
Offline amyk
« Reply #14 on: July 29, 2013, 10:59:22 am »
Typical of DX; wait times can be rather unpredictable.
Offline Psi
« Reply #15 on: July 29, 2013, 11:27:13 am »
I got mine from someone on aliexpress, seems genuine and works really well.
No problems at all.
I have noticed some of the yellow plastic is rubbing off where the iron touches the holder though.
Be interested to know if anyone else has noticed that on genuine units bought from official resellers.
« Last Edit: July 29, 2013, 11:32:00 am by Psi »
Offline baljemmett
« Reply #16 on: July 29, 2013, 01:34:25 pm »
The yellow section of my genuine holder is showing signs of use, in the form of some chipping I think - haven't noticed the colour rubbing off onto the iron, though.  Will try and remember to take a comparison photo this evening...
« Reply #17 on: July 29, 2013, 10:27:33 pm »
Ok Element14 seems to be the cheapest for known genuine that I can find at $187... is that the cheapest for a genuine 220/240V FX-888?
How does the Hakko compare to the Altronics, and DSE stations? I did have the basic $50 Jaycar station for a little while but it only has one tip available for it which is a standard conical tip...
« Reply #18 on: July 30, 2013, 12:27:01 pm »
Ok I've discovered http://www.oritech.com.au/ has them for $174.90inc GST... Element14 has them listed for $170 but thats ex GST so sneakily that ends up being $187... Oritech also does free postage...
I'm thinking that it probably is worth just buying a genuine one, the ones on eBay are about $120 so for extra $50 I can get a 100% genuine one from Australia...
Offline Guppzor
Re: Re: Looking for a Hakko FX-888/FX-888D
« Reply #19 on: July 31, 2013, 10:31:18 am »
The DSE T2200 was my first temperature controlled iron and it served me well for a number of years. It was also the iron in use at the TV and radio repair shop I used to do some part time work at. This was because they were cheap but reliable and fairly hard to break.
I moved to the Hakko because I liked the form factor and had some cash spare at the time :P It was certainly worth it. The temperature is more stable and it does a better job then the T2200 when soldering to large copper pours. That's not saying the T2200 couldn't do it, but the Hakko just feels easier. If you were strapped for cash the T2200 would work well. I would offer mine for a good price but it is my backup iron and the iron I let others use if I'm doing a bit of instructional work ???
If you did go that route I would suggest getting some spare tips just in case DSE decide to discontinue everything associated with DIY and electronics other than consumer stuff :P
Sent from my GT-I9100T using Tapatalk 2
Offline Psi
« Reply #20 on: July 31, 2013, 10:39:45 am »
The digital version T-2250 was also good, mine still works well.
But i doubt you can get it any more.
« Reply #21 on: July 31, 2013, 12:53:23 pm »
Hmm ok, I think I will stick with the Hakko... at least it should be supported for a bit longer, and being an international brand, a large range of tips and parts should be much easier to source...
Everyone seems happy with Hakko, and Dave recommends it... so must be good :)
I want to get a wedge tip as well as per Dave's recommendation... which tip to go with? 1.6mm or 2.6mm (I think thats the correct sizes)?
Offline Psi
« Reply #22 on: July 31, 2013, 01:25:35 pm »
go with 2.4mm for general use
« Last Edit: July 31, 2013, 01:30:44 pm by Psi »
Offline ivan747
« Reply #23 on: July 31, 2013, 02:41:08 pm »
Absolutely, mine was bought from Tequipment.net and it has the same problem. I an guessing this would be hard to copy by someone faking the iron, so we could take this as a sign of authenticity.
Offline nanofrog
« Reply #24 on: August 01, 2013, 12:49:45 am »
Might just be that Hakko decided to source cheap paint as well (tight manufacturing budget).  :o  ;D
