Hi there ,A bit offtopic conversation , but years ago farnell used to sell mains transformer kits (see attachment) so that you could wind you own custom tranny .They where always handy when you needed, a large multi winding transformer with many output V's for a restoration/repair project that you would otherwise have no chance of buying off the shelf . They disapeared from their catalogue in the 90's , I haven't seen them on sale since ,but I have seen these old RS kits pop up on ebay occasionally. They came in various core sizes ,once you had done one of them , you could wind them in less than an hour . They used split bobbins for mains/secondary isolation safety (unless you are a experienced profesional transformer winder with a good understanding of the crucial mains/secondary isolation safety issues involved you shouldn't even attempt single bobbin winding transformers) . There was really nothing special or different about these kit transformers when compared to other off the shelf split bobbin H type trannies ,other than they came in bits ,and you supplied your own winding wire/tape/varnish .
Since these are no longer available ,I always keep a few various size SPLIT BOBBIN transformer's that I find in old equipment ,incase I ever need to wind a 'special' . Once you have had the experience of doing one or two they are pretty easy to rewind ,this is not really an option for begginers though .
In your case, the transformer your asking for really isn't anything special (a 2*24V center tapped secondary ?) ,you should easily get one of these off the shelf .
Regards
