I would go with the Elenco if you want to get yours hands dirty and learn a little on the way. Plenty of space inside to modify it later to suit your requirements.
You could also build your own from scratch without much difficulty, using parts from obsolete electronic appliances in the house.
If you need current limiting functionality straight away, then the Chinese power supply is the easiest solution.
