Hi
Let's say I will use a LTC7000A gate driver to power a load with 24VDC.
How should I select my MOSFET for a 16A max load???
Should I take care about the SOA???
I never really understood that diagram, because I don't know if Vds is 24V or less in full on/off mode.
Let's say I'll take a SUG80050E MOSFET.
Should I consider the blue line (Vds 24V) or the red dot (Vds ~0.1V)
Thanks
Hi
the red dot is where you are at when the mosfet is on
