It is darned cold in this part of the world right now and I have a LIDL Silvercrest electric vest or backwarmer which works pretty well at 240V. The problem is that to work it needs to be plugged into 240 V and I may forget that I am plugged in and jump up from my chair and yank on the cable which is not good at any voltage but much less at 240V.
I would like to insert inline some self release connector and I am thinking of ideas. I am thinking of leaving just a pigtail hanging by my side so I can walk around without the cable getting in the way.
A small co-axial barrel connector would work well mechanically but they are not rated for 240 V and I want something safer.
I have also seen USB connectors held by a magnet and which release easily but also not rated for 240V.
I suppose another requirement is that it be reasonably priced. I am not NASA.
I would love to hear what others suggest. However I don't think a barrel connector would work that well. IMHO. I think the force to break the connection would be too great and it wouldn't work as well as you think. I think a magnetic solution would be best. I have done something similar in the past. Basically machining a custom connector that was magnetic at the connection point. With the magnets being recessed on one end ( the power end) so that accidental contact with power was reduced in the event of accidental disconnect.
"Powerpole" connectors are rated at 600V and more amps than you will ever need. They disconnect easily in my experience and are usually used for auxiliary power connection. You don't say how many wires are involved? Is it 2 wire or 2 + ground?
Two wires. Current should not be a problem as I do not see it exceeding 250 mA max.
Those Powerpole do not look to me like they would release with very little force.
I just want it to be safe to jerk pulling on the cable and to release with almost no force.
Coax are best because of the geometry. Side by side can jam more easily if the pull is sideways whereas coax will always align.
I suppose I could always take some europlug or NEMA 15 and modify the pair so they would release with very little force.
Edit: I see they are rated 3 to 5 lbf which is way too much. I am thinking in terms of, dunno, 250 gr max.
Well, low voltage barrel connectors will come out easily just pulling on the cable.
Magnetic sounds like a great idea but I am afraid I would have to built it myself.
I could also build a barrel type. I have done something similar in the past but I am looking for ideas.
buy a barrel male female extension cut in half. They are less prone to damage.
alternative solution,make a u with the cable close to the connector and use an elastic band to hold the u closed,when you leap up the cable goes tight and you realise your still attached ,the band pings off releasing the cable loop given enough slack to asavoid pulling the cable out the connector.
They are not rated for 240V.
What might work is to use two connectors, one for each wire. Maybe even leave one a bit looser so the other one pulls out first.
I have thought of some solutions of that type but if possible I prefer the easy release solution.
I could hang the cable from the ceiling so I could even move around the room.
Or put a seat belt on the chair which I would have to release after releasing the connector.
In my opinion magnetic is the best solution. I went down this road with a client. The others will not release the way you want. I obviously don't know every solution out there that's why I said I would be curious to see what people come up with. But from all of the suggestions I have seen none of them would release easy enough not to prevent some sort of hazard.
If you think you can build it I would definitely do it.
It is the solution I would like best but making the connector seems to me quite complicated. I have no idea where to begin.
For now I am thinking of just a europlug that enters very loosely and would almost fall out. Put it on the end of a vertical, flexible whip so that gravity will keep it inserted but if pulled the whip will bend and the plug just falls out.
I've already got up from the chair forgetting about the cable several times. I am using a long extension cord but it gets in the way.
I need to keep thinking about this.
It occurs to me that gravity might also be a useful connecting force... build the thing vertically, and let it disconnect when (something) falls over and gets dragged away.
You could use a IEC C7 to C8 extension cord like
https://www.amazon.com/2-Pin-Female-Figure-Adapter-Extension/dp/B07XZT4D86Alternatively, you could repurpose a defect electric kettle.
Place the kettle base on the floor near you.
Reduce the kettle itself the the bare minimum,
with a mains wire coming out of the top, connected to your body warmer.
As soon as you walk away from your chair, the kettle will release from its base and disconnect.
The contacts are going to have some stickiness, so if you make it too loose won't there be a danger of 240V across iffy contacts?
Perhaps an alternative might be motorcycle gear, which is designed for 12V and a very cold environment.
Rube Goldberg? Is that you?
The extension cord would not work without modification precisely because they are made to not disconnect accidentally and require some force. I guess modifying one might work.
The kettle idea is out of the question but it does give me some idea of a different approach to a different type of connector. That type of connector and magnets to keep it connected in place might work.
The more I think about it the more I see magnets being in the answer.
IEC C7 leads (shrouded two hole figure 8 ) pull straight out of C8 inlets very easily, especially when worn. Unfortunately a C8 inline connector is not readily available, so your options there are either to 3D print a shell with an cord grip and strain relief to fit round a clip in panel mount C8 connector or butcher a C7 to C8 extension lead (as spostma suggested) and either do a very robust splice of the C8 side to the controller power input lead, or better, rewire the controller with it. I would also suggest anchoring the connector tail to a belt clip, so it doesn't pull on the control box.
You have just given me an idea. I have several C7/8 extension cords that came with some kitchen under-cabinet lights which could be daisy chained. I will start experimenting by shaving them off a bit because as they are they most definitely do not disconnect easily.
Two pole lawnmower plug and coupler? Pulling apart is exactly why the things exist, and they are mains rated.
https://www.amazon.co.uk/ORANGE-CONNECTOR-LAWNMOWER-CATALOGUE-MERCURY/dp/B01L4P0J64 or words to that effect.
PSA)
That looks promising, but I would strongly recommend looking for one from a real (i.e. physical) store. If I replace ".co.uk" with ".com", I get a product picture that obviously matches the intended product, but the description is "Adult Socks Medium Men's Athletic Socks Sweat Absorption Personality Cartoon Male (5 Pair)". I wouldn't want to buy anything that has the chance of burning down my house from a seller that plays those sorts of games with their product listings!
I don't think that kind of listing problem reflects on the quality of the product - they are all selling the same thing, and none of them either manufacturer it or know wtf it is or does. All the listing thing is indicating is that the seller can screw up listings (intentionally or otherwise).
Well, maybe not, but...
...that sounds exactly like an
excellent reason to not buy from them, at least not anything that has the potential to burn down my house if it doesn't work. Those sorts of things I want to buy from someone that warrants the product. I doubt a seller that "[doesn't] know wtf it is or does" can give me any such assurance.
Before buying, watch
(he's specifically talking about electrical connectors!). And buy from a reputable brand.
(PSA)
That has absolutely nothing to do with the seller which seems to me to be the UK manufacturer of the product.
It seems to me to be a malfunction of the Amazon server and, in any case, you made up that URL so it seems to me you just discovered a glitch in the Amazon website.
Searching Google the same product can be found from eBay and other sources.
https://www.electricals247.co.uk/2-pin-orange-rubber-connector-5a-in-line-garden-lawnmower-2pfc10-1-34925/
...that sounds exactly like an excellent reason to not buy from them, at least not anything that has the potential to burn down my house if it doesn't work.
Yes, indeed. But you were saying that the product was probably duff because of the shit listing, not because it was on Amazon.
