Since it seems there's the need to add some clarification to my previous post, here I am again.
First let's understand that one may have different approaches (experience) to electronics. If you are designing something, the part data-sheet has to be observed thoroughly, but when troubleshooting, an empirical approach will suffice.
I bought a DE-5000 to (try) be more thorough. I had an Elektor ESR meter for years to troubleshoot, and has served me well. So, lets say I've been more empirical in the subject.
But I may have to recall that my previous table was to compare this 2 meters. If I had selected different test frequencies in the DE-5000 according to the best suited for the capacitor, then my results would be meaningless to me, since the Elektor ESR meter only generates 100kHz. Please see photos attached from the output of the meters. By the way... I couldn't observe nothing useful from the BSIDE, in the scope, since it must generate a few test signals to figure out what he has connected in the input (a diode, resistor, capacitor, transistor...).
About the table and is values: It has the title "ESR" on line 1, so by default this should mean Ohm, but yes, I didn't mention that. Sorry.
Column B is marked "uF", meaning micro Farad, and column C is marked "V" meaning Volt.
On columns D, E and F we have the test results in Ohm (not stated. My bad
), and the test frequency set of 100kHz (apart from BSIDE that is unknown to me)
Concerning the correct test frequency to measure the ESR, one approach is to check the data-sheet, but it shouldn't be left out the real intended application. Though 120Hz is regularly mentioned for big capacitors, I think (and might be wrong, and if so, let me know) this has to be to the fact that they are largely used in linear PSUs for filtering, and being 60Hz the frequency of power grind in US, there's a regular reference to 120Hz (frequency doubles after bridge rectifier). Well, if this is the case and I want to be picky, I should use 100Hz instead because in Portugal the power grid frequency is 50Hz. But hey!... I have a 4700uF in the output of another Elektor gadget, a Generator based on a XR2206 that goes up to 200kHz. For this purpose, I definitely will test the capacitor at 100kHz, no matter what the data-sheet my state.
A note: one must not forget that ESR changes with a few things like temperature, but most important to me, the voltage. So the expected ESR for a, let's say, 1000uF capacitor will be different if it is for 10V or for 300V.
In my previous post, i meat to say what I said (apart from the missing "Ohm" for ESR), and I though I had described well enough my intend purposes for the table provided. Sure it was not the best of the examples, or a broad one, but it was
one, and it was meant to be just
one example, nothing more.
To frame my approach, I'm not an electronics Pro, and most of my "doing" is for hobby. So the Pro's forgive my lack of assertiveness, but always fell free to correct me. As I say to my kids: "Errors will always occur, but what is wrong is not trying to correct them". (And so, learn from them)
