Author Topic: Low cost soldering station/iron and multimeter for a beginner  (Read 6556 times)
Offline MarkF
Re: Low cost soldering station/iron and multimeter for a beginner
« Reply #25 on: May 09, 2022, 09:50:39 am »
I bought the Hakko FX888D and very happy with it.
The Hakko FX888D is available from tEquipment for $104.95 minus the 6% EEVBlog discount.
   https://www.tequipment.net/HakkoFX888D-23BY.html?v=118031
The following users thanked this post: forumate
Offline forumateTopic starter
« Reply #26 on: May 09, 2022, 04:22:51 pm »
Not shipping to me :(
Thanks everyone! Regarding the station, I will use a cheap iron for now,
For the Multimeter I think I will buy the UNI-T UT133A. What do you think?
It seems to be designed as an electrician's meter but it should work just fine for hobby circuits. It claims a "fast capacitance measurement" which is nice but there are couple of things it lacks...
for instance, it doesn't seem to be able to measure duty cycle and the frequency measurement only goes up to 1 MHz. For microcontroller work it would be nice to be able to measure higher frequencies.
https://www.uni-trend.com/meters/html/product/General_Meters/DigitalMultimeters/UT133_Series/UT133A.html
Update: You might find this compilation of reviews helpful. Then again, it might just further complicate your decision making process.
https://lygte-info.dk/info/DMMReviews30.html
True, but it also shows me that the UNI-T units are actually some of the best there and safe! So I will probably get a cheap UNI-T (like the UT133A) instead of other cheap! TY!
I see the weller wlc100 is on amazon for $34. I have had one for many years and it works fine. Maybe the new ones aren't as good. I upgraded to a Hakko FX888D-23BY--nice catchy model number. It appears to be working well--but had to buy extra tips right away to get a wider tip for bigger soldering tasks. I liked the idea of it telling me when the tip reached temperature. I like the reviews on amazon, and for whatever reason, soldering irons and stations have lots of bad review--presumably cost cutting on the manufacturing side. Again on amazon, lots of inexpensive multimeters. Even if you don't buy from amazon, its a nice place to look at reviews and see what people's experience is. I have had good experiences with digi key and mouser. For those in america at least.
That's a great option! In fact it looks really good, will see if they have the 240V somewhere! TY!!
EDIT: These are my final contenders for a multimeter (all UNI-T):
1) UNI-T UT33A+
2) UNI-T UT133A
3) UNI-T UT136B+
4) UNI-T UT136C+
Which one do you think would be the best out of these?
« Last Edit: May 09, 2022, 04:29:15 pm by forumate »
Offline wizard69
« Reply #27 on: May 10, 2022, 02:55:37 am »
I kinda think you are going about this the wrong way.   Everybody has their favorite when it comes to meters, usually older ones that they last owned.   Instead look towards the major supplier so meters to see what is new from the reputable manufactures.   In other words go on a web site like Digikey and sort the available meters by price.   On Digi they have almost 55 meters under $50.
I have no problem with you buying a cheap meter as long as you are working on low voltage DC circuits.   However if your interest take you to audio equipment or other items that expose you to line voltages I'd suggest looking for a CAT rated meter.   A meter with an honest CAT rating which would mean the more established manufactures.   Don't waste your money before you really have nailed down your needs.   There are many good meters to consider, for example: Triplett MM350 and a whole bunch more under $50
Which brings up another point, if you get into electronics, it will be really easy to feel the need for a second meter.   One of those should be a higher performance meter.   So sometime in the future you should plan on buying a higher end meter.
As for soldering you might not need one immediately if working from a breadboard.  My problem with soldering irons is that you end up needing more than one.   One for the bench, one for working of ladders and other heights, one for high power and maybe even a reflow oven.   Back in the day if I was working remotely we had butane power irons as crude as they where and really poor battery powered irons for very light work for example.   At the bench Weller seemed to be one of the better options and still is from what I can see.  Even at the bench you can run into needing more that one iron or sometimes a tip.
In any event when it comes to irons what really makes th difference is easy access to repair parts.   This especially for tips and heating elements.  Tips have to be replaced fairly regularly and you often need tips of different designs.   As such buy an iron that is well supported by the vendor you buy from and can get you replacement supplies fast.   If there is one thing in an electronics lab that should be sourced locally it is the iron, make sure your vendor supports it well and that you have lots of options.   I wouldn't go international to buy an iron, that is fine for a lot of other lab equipment, I just don't see it making sense for an iron.
A good soldering iron station is not cheap, however if you look at them as an investment that should last multiple decades the cost is pretty trivial on a day to day basis.   I might suggest that buying an iron, such as a WLIR3012A might be good enough to get started on.   It will keep the entry cost low until you can invest a hundred or so $$$$$ in a decent station.   A nice entry level station like the WE1010NA can set you back $150 and frankly that can detract from a lot of other stuff you may need to get started.   YOu didn't mention where your interests are exactly, but you can easily end up spending a bit of cash just to get started working with Arduino's.   I know from my early years how hard it was to get the parts and equipment to do anything.   The getting is far easier today but the cost is still real.
Think about it this way, the iron is just the hot part of soldering you will need to buy solder, flux, flux remover, a solder sucker, brushes, sponges and other goodies just to get started.  If you don't have them already there will be a few hand tools too.   All of this just to solder.
In any event I'm thinking constrained budget here.   If you have the cash to burn then it makes a lot of sense to skip entry level.
1) UNI-T UT33A+
2) UNI-T UT133A
3) UNI-T UT136B+
4) UNI-T UT136C+
« Reply #28 on: May 10, 2022, 03:43:48 pm »
Thank you !!!
I do understand what you mean, but all of the brands you mentioned simply don't ship to me / available where I live. Regarding the iron/station: I got a cheap one from a friend and I realized it does the job for my current usage, that's why until I get more experienced I don't think I will need anything more, but of course I'm planning to get better one.
As for the multimeter: I saw a review showing that the UNI-T units are actually solid and are truly rated, they have ceramic fuses and, one review actually tested the 1000V rated UNI-T and it passed
Also their fuses are available for cheap unlike some other brands where it's hard to find fuses
That's why I think their $20-30 units are good for my needs, since they are also safe and true to the specs
Offline Romualds
  • Country: lv
« Reply #29 on: May 13, 2022, 05:44:14 pm »
Did something happen to Uni-T? Looks like their official AliExpress store disappeared
Aliexpress isn't the only place for buying Uni-T equipment. I recently bought UT61E (not Plus ) for 50 USD on eBay. It is still available there from two vendors (from US and China).
BTW, Uni-T homepage is still up and running (https://www.uni-trend.com/meters/).
« Last Edit: May 14, 2022, 03:34:24 am by Romualds »
Offline tooki
« Reply #30 on: May 14, 2022, 03:43:25 pm »
Some years ago I bought an "ERSA MS 250 S Electronic Soldering Station", which comes with two DC soldering irons, the bigger one (12VDC/25W) for rougher stuff, and the smaller one (12VDC/6W) for more fragile stuff.
There are various more sophisticated soldering stations, but this station in combination with an ESD wrist wrap is a good base for soldering discrete electronics.
That station was discontinued years ago*, so what good is recommending it? (Plus, the OP is in USA where Ersa equipment is hard to find and priced very high.)
Besides, I honestly don’t think 25W is a good starting point these days. Lead-free solder increases heat requirements slightly, but the multilayer, plated-through-hole boards that are common now just suck heat away like there’s no tomorrow.
*present in the 2005 catalog, but gone by the 2008 catalog. I couldn’t find 2006 or 2007.
