Im looking for a low power (few microamps or even nanoamps) chip capable of generating low frequency PWM signals in the range of 50-200Hz but with a very small duty cycle, like 0.2-4%. i found several adjustable oscillators but in the MHz range, which helps with the d.c. but frequency then is a problem. Is there an IC that does this? I'm looking for a chip, if it even exists, not how to make my own circuit
Thank you
