Author Topic: LTC3780 board - replacing trimmers with pots  (Read 2845 times)
Offline bogdan2014Topic starter
« on: April 08, 2019, 03:53:01 pm »
I got a pair of these boards and I want to build two variable bench power supplies out of them. I would like to replace the two trimpots V-adjust and I-adjust with actual panel potentiometers. I was initially looking for 10 turn pots but at those values (500k and 200k) they're pretty rare and expensive.
I don't like the idea of having two of them for coarse and fine adjustment either, so is there a way to lower the value of the pots while retaining the whole range of voltage and current?
Sent from my Poco F1 using Tapatalk
Offline TimNJ
Re: LTC3780 board - replacing trimmers with pots
« Reply #1 on: April 09, 2019, 05:34:38 pm »
Do you have a schematic for this board? If not, my guess is that they are using the application circuit, or something very similar.
You can re-scale the output voltage/current networks quite easily. However, this may require re-compensating the error amplifier (pin ITH).
See attached images.
Offline LateLesley
  • Country: scotland
« Reply #2 on: April 09, 2019, 06:03:26 pm »
It may be possible. I had a look at the LTC3780 datasheet, and the voltage adjust seems to be done with a voltage divider, so it may be easy to change the pot value by changing the fixed resistor in the divider.
https://www.analog.com/media/en/technical-documentation/data-sheets/LTC3780.pdf
If you look at page 21 it gives the equation for working out the voltage divider for the circuit on page 26 (R1, R2). So if you find the resistor(s) connected to the voltage pot, you should be able to find out which ones to change. It is entirely possible that they just used the pot across the output, and the wiper to the chip, in which case you could just swap the pot for any value without the need to change anything else, but you do want as high a resistance as possible, as it would be across the supply.
The current might be a little more problematic, as i'm not sure the mechanism it is using to control that. I suspect it may be a pot connected to the ITH and fed from a voltage reference somewhere, so you might need to trace out its circuit before you get suggestions to change it.
« Last Edit: April 09, 2019, 06:08:15 pm by LateLesley »
