House_number and the group,
You have too many ground connections in this LTspice circuit:
D3 is shorted in the bridge rectifier. You need to remove the ground connection connected to V1.
The DC operating point calculation treats capacitors as open circuits and inductors as short circuits, giving you the steady-state bias voltages and currents.
In this circuit:
The DC operating point is calaculated at time=0. At time equals 0, sine(0) = 0, there is no voltage on any of the nodes in the model.
Changing the model to start with the sine wave at a peak, 90 degrees, SINE(0 17 50 0 0 90), the model starts with the sine wave at a peak.
There is voltage on C1. The voltage is 17V from V1, minus two time the forward voltage drop of the diodes. There is no ripple. The DC analysis is snap shot in time.
This is the wrong type of analysis for this circuit. Use the
.step param ... directive to change the load current
Regards,
Jay_Diddy_B
