Author Topic: LTspice FFT on current waveform?  (Read 5304 times)
Offline questronTopic starter
« on: November 07, 2014, 05:36:02 am »
how could i do an FFT on a current waveform in LTspice?
i did a .four i(lc(Q1)) for example, it didn't work.
i just want the THD number on an AC current, does this make sense, doable in LTspice, what's the correct syntax for it?
googling didn't yield any results.
tks!
Offline T3sl4co1l
    • Seven Transistor Labs
Re: LTspice FFT on current waveform?
« Reply #1 on: November 07, 2014, 07:47:53 am »
If nothing else, do the .tran simulation, plot the waveform, then View / FFT.
Seven Transistor Labs, LLC
Offline macboy
« Reply #2 on: November 07, 2014, 03:27:15 pm »
This is the way to get a graphical result. To get a tabulated list of amplitudes of harmonics, use ".four" directive. The OP is missing the frequency from the .four directive. This should work (for 1 kHz):
.four 1kHz Ic(Q1)
Also ensure that the simulation time is an exact multiple of the period of the fundamental, in order to improve the FFT result (to avoid a slant of the noise floor towards DC). Also add this directive:
  .option plotwinsize=0
...which will disable compression, which would otherwise increase distortion due to reduced precision in calculations.
« Last Edit: November 07, 2014, 03:29:17 pm by macboy »
« Reply #3 on: November 07, 2014, 04:52:59 pm »
did that and got a rough idea about its distortion, thank you Tim for the help!
« Reply #4 on: November 07, 2014, 04:59:03 pm »
.four 1kHz Ic(Q1)
that worked beautifully, thanks a lot macboy!
didn't know the impact on slanting noise floor before, very nice and useful tip!
all is much appreciated!
