Sometimes the received packet write to Coordinator correctly. But some time missing of characters and mixing up is occurring.
* \file WSNDemo.c
* \brief WSNDemo application implementation
* Copyright (C) 2012-2014, Atmel Corporation. All rights reserved.
* \asf_license_start
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions are met:
* 1. Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
* 3. The name of Atmel may not be used to endorse or promote products derived
* from this software without specific prior written permission.
* 4. This software may only be redistributed and used in connection with an
* Atmel microcontroller product.
* THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR IMPLIED
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE
* EXPRESSLY AND SPECIFICALLY DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
* STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
* ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
* \asf_license_stop
* Modification and other use of this code is subject to Atmel's Limited
* License Agreement (license.txt).
* $Id: WSNDemo.c 9267 2014-03-18 21:46:19Z ataradov $
/*- Includes ---------------------------------------------------------------*/
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include "config.h"
#include "hal.h"
#include "phy.h"
#include "sys.h"
#include "nwk.h"
#include "nwkRoute.h"
#include "nwkSecurity.h"
#include "sysTimer.h"
#include "halUart.h"
#include "halSleep.h"
#include "halBoard.h"
#include "halLed.h"
#include "commands.h"
/*- Definitions ------------------------------------------------------------*/
#if defined(APP_COORDINATOR)
#define APP_NODE_TYPE 0
#elif defined(APP_ROUTER)
#define APP_NODE_TYPE 1
#else
#define APP_NODE_TYPE 2
#endif
#define APP_CAPTION_SIZE (sizeof(APP_CAPTION) - 1)
#define APP_COMMAND_PENDING 0x01
#define APP_ENDPOINT 1
#define APP_LED_NETWORK 0
#define APP_LED_DATA 1
/*- Types ------------------------------------------------------------------*/
typedef struct PACK
uint8_t commandId;
uint8_t nodeType;
uint64_t extAddr;
uint16_t shortAddr;
uint32_t softVersion;
uint32_t channelMask;
uint16_t panId;
uint8_t workingChannel;
uint16_t parentShortAddr;
uint8_t lqi;
int8_t rssi;
struct PACK
uint8_t type;
uint8_t size;
int32_t battery;
int32_t temperature;
int32_t light;
} sensors;
struct PACK
uint8_t type;
uint8_t size;
char text[APP_CAPTION_SIZE];
} caption;
} AppMessage_t;
typedef enum AppState_t
APP_STATE_INITIAL,
APP_STATE_SEND,
APP_STATE_WAIT_CONF,
APP_STATE_SENDING_DONE,
APP_STATE_WAIT_SEND_TIMER,
APP_STATE_WAIT_COMMAND_TIMER,
APP_STATE_PREPARE_TO_SLEEP,
APP_STATE_SLEEP,
APP_STATE_WAKEUP,
} AppState_t;
static void appSendData(void);
/*- Variables --------------------------------------------------------------*/
static AppState_t appState = APP_STATE_INITIAL;
#define APP_BUFFER_SIZE NWK_MAX_PAYLOAD_SIZE
#if defined(APP_ROUTER) || defined(APP_ENDDEVICE)
static NWK_DataReq_t appNwkDataReq;
static SYS_Timer_t appNetworkStatusTimer;
static SYS_Timer_t appCommandWaitTimer;
static bool appNetworkStatus;
#endif
static AppMessage_t appMsg;
static SYS_Timer_t appDataSendingTimer;
static uint8_t appDataReqBuffer[255];
static uint8_t appUartBuffer[255];
static uint8_t appUartBufferPtr = 0;
static uint8_t flag=0;
/*- Implementations --------------------------------------------------------*/
void HAL_UartBytesReceived(uint16_t bytes)
for (uint16_t i = 0; i < bytes; i++)
uint8_t byte = HAL_UartReadByte();
if (len(bytes)==0)
flag=1;
//if (appUartBufferPtr == sizeof(appUartBuffer))
//appSendData();
if (appUartBufferPtr < sizeof(appUartBuffer))
appUartBuffer[appUartBufferPtr++] = byte;
static void appUartSendMessage(uint8_t *data, uint8_t size)
uint8_t cs = 0;
//HAL_UartWriteByte(0x10);
//HAL_UartWriteByte(0x02);
for (uint8_t i = 0; i < size; i++)
if (data[i] == 0x10)
// HAL_UartWriteByte(0x10);
cs += 0x10;
HAL_UartWriteByte(data[i]);
cs += data[i];
//HAL_UartWriteByte(0x03);
cs += 0x10 + 0x02 + 0x10 + 0x03;
// HAL_UartWriteByte(cs);
static bool appDataInd(NWK_DataInd_t *ind)
AppMessage_t *msg = (AppMessage_t *)ind->data;
HAL_LedToggle(APP_LED_DATA);
msg->lqi = ind->lqi;
msg->rssi = ind->rssi;
appUartSendMessage(ind->data, ind->size);
if (APP_CommandsPending(ind->srcAddr))
NWK_SetAckControl(APP_COMMAND_PENDING);
return true;
static void appDataSendingTimerHandler(SYS_Timer_t *timer)
if (APP_STATE_WAIT_SEND_TIMER == appState)
appState = APP_STATE_SEND;
else
SYS_TimerStart(&appDataSendingTimer);
(void)timer;
static void appNetworkStatusTimerHandler(SYS_Timer_t *timer)
HAL_LedToggle(APP_LED_NETWORK);
(void)timer;
static void appCommandWaitTimerHandler(SYS_Timer_t *timer)
appState = APP_STATE_SENDING_DONE;
(void)timer;
#endif
static void appDataConf(NWK_DataReq_t *req)
HAL_LedOff(APP_LED_DATA);
if (NWK_SUCCESS_STATUS == req->status)
if (!appNetworkStatus)
HAL_LedOn(APP_LED_NETWORK);
SYS_TimerStop(&appNetworkStatusTimer);
appNetworkStatus = true;
else
if (appNetworkStatus)
HAL_LedOff(APP_LED_NETWORK);
SYS_TimerStart(&appNetworkStatusTimer);
appNetworkStatus = false;
if (APP_COMMAND_PENDING == req->control)
SYS_TimerStart(&appCommandWaitTimer);
appState = APP_STATE_WAIT_COMMAND_TIMER;
else
#endif
#ifdef NWK_ENABLE_ROUTING
appMsg.parentShortAddr = NWK_RouteNextHop(0, 0);
#else
appMsg.parentShortAddr = 0;
#endif
appMsg.sensors.battery = rand() & 0xffff;
appMsg.sensors.temperature = rand() & 0x7f;
appMsg.sensors.light = rand() & 0xff;
//appUartSendMessage((uint8_t *)&appMsg, sizeof(appMsg));
appState = APP_STATE_WAIT_SEND_TIMER;
#else
if(flag==1)
memcpy(appDataReqBuffer, appUartBuffer, appUartBufferPtr);
appDataReqBuffer[appUartBufferPtr+1]=0x23;
appNwkDataReq.dstAddr = 0;
appNwkDataReq.dstEndpoint = APP_ENDPOINT;
appNwkDataReq.srcEndpoint = APP_ENDPOINT;
appNwkDataReq.options = NWK_OPT_ACK_REQUEST | NWK_OPT_ENABLE_SECURITY;
appNwkDataReq.data = appDataReqBuffer;
appNwkDataReq.size = appUartBufferPtr;
appNwkDataReq.confirm = appDataConf;
HAL_LedOn(APP_LED_DATA);
NWK_DataReq(&appNwkDataReq);
appState = APP_STATE_WAIT_CONF;
else
#endif
static void appInit(void)
appMsg.commandId = APP_COMMAND_ID_NETWORK_INFO;
appMsg.nodeType = APP_NODE_TYPE;
appMsg.extAddr = APP_ADDR;
appMsg.shortAddr = APP_ADDR;
appMsg.softVersion = 0x01010100;
appMsg.channelMask = (1L << APP_CHANNEL);
appMsg.panId = APP_PANID;
appMsg.workingChannel = APP_CHANNEL;
appMsg.lqi = 0;
appMsg.rssi = 0;
appMsg.sensors.type = 1;
appMsg.sensors.size = sizeof(int32_t) * 3;
appMsg.sensors.battery = 0;
appMsg.sensors.temperature = 0;
appMsg.sensors.light = 0;
appMsg.caption.type = 32;
appMsg.caption.size = APP_CAPTION_SIZE;
memcpy(appMsg.caption.text, APP_CAPTION, APP_CAPTION_SIZE);
HAL_BoardInit();
HAL_LedInit();
NWK_SetAddr(APP_ADDR);
NWK_SetPanId(APP_PANID);
PHY_SetChannel(APP_CHANNEL);
#ifdef PHY_AT86RF212
PHY_SetBand(APP_BAND);
PHY_SetModulation(APP_MODULATION);
#endif
PHY_SetRxState(true);
#ifdef NWK_ENABLE_SECURITY
NWK_SetSecurityKey((uint8_t *)APP_SECURITY_KEY);
#endif
NWK_OpenEndpoint(APP_ENDPOINT, appDataInd);
appDataSendingTimer.interval = APP_SENDING_INTERVAL;
appDataSendingTimer.mode = SYS_TIMER_INTERVAL_MODE;
appDataSendingTimer.handler = appDataSendingTimerHandler;
appNetworkStatusTimer.interval = 500;
appNetworkStatusTimer.mode = SYS_TIMER_PERIODIC_MODE;
appNetworkStatusTimer.handler = appNetworkStatusTimerHandler;
appCommandWaitTimer.interval = NWK_ACK_WAIT_TIME;
appCommandWaitTimer.mode = SYS_TIMER_INTERVAL_MODE;
appCommandWaitTimer.handler = appCommandWaitTimerHandler;
#else
#endif
#ifdef PHY_ENABLE_RANDOM_NUMBER_GENERATOR
srand(PHY_RandomReq());
#endif
APP_CommandsInit();
static void APP_TaskHandler(void)
switch (appState)
case APP_STATE_INITIAL:
appInit();
} break;
case APP_STATE_SEND:
appSendData();
} break;
case APP_STATE_SENDING_DONE:
#if defined(APP_ENDDEVICE)
appState = APP_STATE_PREPARE_TO_SLEEP;
#else
#endif
} break;
case APP_STATE_PREPARE_TO_SLEEP:
if (!NWK_Busy())
NWK_SleepReq();
appState = APP_STATE_SLEEP;
} break;
case APP_STATE_SLEEP:
HAL_LedClose();
HAL_Sleep(APP_SENDING_INTERVAL);
appState = APP_STATE_WAKEUP;
} break;
case APP_STATE_WAKEUP:
NWK_WakeupReq();
HAL_LedInit();
} break;
default:
break;
int main(void)
SYS_Init();
HAL_UartInit(9600);
while (1)
SYS_TaskHandler();
HAL_UartTaskHandler();
APP_TaskHandler();
I'm using this code for Router and Coordinator.
