Hello there,
You can't really measure just the output of the bridge you first have to measure the input of the bridge. That's because the input line could be something other than 120vac. The normal range is 108vac to 132vac so you could possibly have anything between those two. Normally you would get something close to 120vac, but you should use your meter for that anyway so you will know how your meter interprets that voltage. It could also vary significantly over the course of one day.
The input at the bridge rectifier is about 122 V.
Hello again,
Ok then you would multiply the theoretical values by 122/120.
I have a question though. What is going to be the purpose for measuring this quantity? Normally you don't really measure that until you have some load or some filter capacitance or something else like that. Is this a study of some type?
I was just honestly playing around there is no particular purpose.
I have a bridge rectifier that is set up to go into mains directly. So all I really have to do is just plug it into the wall and everything is insulated and there are jacks on the output for the multimeter. Because of me playing around I now have this question I am trying to figure out with this particular meter.
Hi again,
Oh ok no problem, so this more or less falls into the category of self study, which is always a good thing. You can learn a lot like that.
The bottom line to your original question seems to me to go like this.
If you have meter A and you read 80v, and you have meter B and you read 90v, then the two meters are using a different method to measure the voltage, or there is something wrong with one of the meters. You could try a third meter C to see if it matches with either one of the first two.
The same would apply to different settings on a single meter. If setting A produces 80v and setting B produces a reading of 90v, then the two settings are using a different technique to measure the voltage, or else the meter is not made quite right. Again another meter might help to decide which reading is right, or at least close to right.
You should be aware that a true RMS reading is done differently than a regular AC measurement on a run of the mill meter. A true RMS method is done in a way that samples the wave in different places and builds up a reading. A regular AC measurement just measures the peak or the average and uses a correction factor (sometimes called the 'crest factor') to display the reading. The two would read vastly different values on a full wave rectified waveform.
I am not sure what measurements would be useful here either, except the true RMS value or the average DC value. Once you add a capacitor though, the average DC value will change. The capacitor can store energy during the low voltage time periods and thus the average DC voltage becomes higher in value, effectively giving you more power output.
The theoretical values of the full wave output is of interest though. You can also do a spectrum analysis to see the levels of the different harmonics.
