So I am taking 120V mains and running it through a full bridge rectifier.
This is what I get from my multimeter.
The following readings are at the output of the bridge rectifier.
On VDC reads 114
On VAC reads 35
On AC + DC reads 124
On dual display DC reads 114 and AC reads 50
I assume the last 2 readings are not the same because of a phase shift. Am I interpreting this correctly?
Hello there,
You can't really measure just the output of the bridge you first have to measure the input of the bridge. That's because the input line could be something other than 120vac. The normal range is 108vac to 132vac so you could possibly have anything between those two. Normally you would get something close to 120vac, but you should use your meter for that anyway so you will know how your meter interprets that voltage. It could also vary significantly over the course of one day.
We can look at some theoretical data, but your meter may show some unusual readings because meters respond differently to different harmonics, and there are a bunch of harmonics present in the output of the bridge.
Most notable, you do not see the same frequency on the output as on the input because the fundamental becomes two times the input frequency. That means the lowest frequency, with a line input of 60Hz, is 120Hz. Most meters can respond to that though, but you never know without checking the spec's of the meter. The amplitude is about 72 volts peak which means about 50.9vrms, but there are also harmonics that add up to more, plus the DC component. The average DC however is around 108v.
Normally you have some sort of load on it too, and also usually some capacitance that can filter the bumps into a more smooth DC output. With little load you would see the peak voltage which would be close to 170v peak when you have a capacitor to filter the output.
You have to be careful with the selection of the capacitor though, it has to be able to handle the full peak of 170v and preferably with a rating 250v or more.
Different meters respond differently to frequencies not in the 60Hz to maybe 400Hz so it's hard to say what the meter will read exactly. It is however possible to calculate all that if we know the input voltage for sure.
