How does this work the inductors, (and relay), are a mystery, I know how a normal doubler, or tripler etcetera works but this seems one step beyond:
http://www.ur4ll.net/#trans3 See item Multiplier X4
Thanks.
If you look at the board, it says +600 and -600.
My guess is it is simply two multipliers, one for neg and one for pos.
The other stuff is perhaps filtering and a relay to switch on the thing, perhaps with a current limiting w/w resistor.
Is there supposed to be a circuit for this 4x multipler on that page, i cant see it
Edit: hm.. that's odd, it just magically appeared the next time i loaded the page.
I can't see a circuit. Just a .jpg of the board.... Is it a .pdf or what? Thanks.
It's just a link to a photo of the PCB, I shouldn't have used the word circuit.
