Author Topic: Malfunctioning magtek stripe reader: measure crystal resonator easily?  (Read 3317 times)
Offline Erwin RiedTopic starter
  • Country: no
I was trying to use an old ps2 magtek stripe reader, this one:
It was working years ago, but after that I just stored the device. Now the red led stays lit and the reader sings a little song (probably reporting a failure: low tone, high, high, low, high, high, ...) I checked inside and the only thing strange is a rusted crystal labelled MMD160AK (I guess is 16 mhz?). Is there a way to quickly check this?
I had several crystals, and using a 16 mhz the song continues but sometimes the led just stays red, no song.
Any hint? Is not sending anything thru the ps2 port, only 0xFF bytes when connecting.
My website: http://ried.cl
Offline HalfSpace
Hi Erwin Ried,
If it sings the same tune with a 16MHz crystal I think you have picked the correct frequency.
Does the reader have an optical sensor to detect a card is present or is it completely magnetic sensing?
The card sensor may not be working and the reader may think it has a card in it when you power it up.
HalfSpace  :)
"He who asks a question is a fool for five minutes; he who does not ask a question remains a fool forever."
  • Country: no
Hi HalfSpace
Right! it was a 16 mhz. Tested different values and the song changed :D no insertion sensor, the reader made a beep after a card was slided but that was probably due the magnetic header readout (always powered?)
Offline HalfSpace
Hi Erwin Ried,
Are you running the reader from a PC or a microprocessor project?
The reader may require handshake data between the PC (or project) and itself to start working.
Here is a link for the PS/2 protocol which may help.
http://www.computer-engineering.org/ps2protocol/
When the reader was working years ago what did you run it on?
HalfSpace  :)
  • Country: no
hi again,  both times was from an arduino. Same code. I later tried it on the computer,  same little song. May the rom is corrupted or something like that after so many years stored?
Offline HalfSpace
Hi Erwin Ried,
Rom chips rarely fail. Can you post some pictures of the PCBs?
HalfSpace  :)
  • Country: no
Hi, here are the photos:
The board with most of the chips is the main one, I removed that ROM and song stops, so probably that's doing something :D. I broke a buzzer (plastic part in the lower part) and removed the crystal:
Very few stuff to see, and the only thing that seemed damaged was the crystal.
Offline HalfSpace
Hi Erwin Ried,
The EEprom (24C04A) looks like it has been re-soldered, has this been removed or replaced?
Operation manual for the Magtec mini.
http://www.magtek.com/documentation/public/99875123-11.03.pdf
The link below has some documentation on Magtec readers.
http://stripesnoop.sourceforge.net/devel/index.html
This PDF has data on the Magtec analog head reader IC in appendix B.
http://stripesnoop.sourceforge.net/devel/magtek-io.pdf
HalfSpace  :)
  • Country: no
Thanks. I'll take a look at these links. Yes, I resoldered it because there was some corrosion from the crystal,  just to be sure.
