I purchased a Mastech HY3005F-3 power supply. It typically works fine but maybe 50%-75% it trips a 20A breaker with nothing else connected to it. Reset the breaker and then it's usually ok. It has a toriodal transformer and is connected on the secondary entirely with plug connectors. I disconnected all secondaries and powered up and the breaker still trips. I have used two different circuits/breakers and am not overloaded on either. I removed three MOV's which two were parallel to the each side of the switch (but I cannot see how a MOV failure here could cause a problem) and a third which was across line/neutral. Still trips the breaker. Could the circuitry on the secondary side somehow limit the inrush current and there is a failure there or is inrush always limited on the primary side? If so there's really nothing there to do it. I appreciate any tips.
