Could this new product
really have such a high-resolution ADC as its 6-digit display would seem to indicate? I suppose if the BT protocol was hacked and it was powered externally by a variable 5 to 15 volt reference, one could double its functionality as a quasi 10,000 count voltmeter and portable logging device (without ever opening it...)
DiodeGoneWild opened one at about the 9 minute mark (maybe the ADC is the SSOIC-10 above the current shunt?)
TheHWCave did a video on using a USB tester (a TC66) that employs an TI INA226 as a 5.5 digit DC meter:
Using the TC66 USB tester as a $30 5½ digit precision multi-meter -- TheHWCave
https://youtu.be/iZ5JjA6DoZgAnd his teardown/review of the TC66:
Ruideng TC66 / TC66C USB Type-C Tester - Way too good for just USB!
https://youtu.be/rOlhibDUJgs
That really does seem like an excessive number of decimal places for a simple USB tester. I think I would have gone for a faster update rate instead.
Edit: It does look like it might have potential for other uses though.
Thanks! That TC66C seems like it would also work, but I overlooked negative voltages (it would take some work!)
TheHWCave provided a good reference:
https://sigrok.org/wiki/RDTech_TC66CI think it would require an isolated outboard front-end with a stable 15v reference, along with a summing amp capable of a linear 20v swing. A basic BT app would offset displayed readings as -10.0v=5.0v, 0.0v=15.0v, and +10.0v=25.0v together with a 10x and 100x decimal shift for good measure, pardon the humour
I'd bet Joe Smith could make this look easy, like a Sunday walk in the park with his dog.
24V / 0.0001V = 240,000. So it would seem to be an 18-bit+ ADC.
Could be MAX11212, or some China clone equivalent. Or they are oversampling on a 12/14-bit converter.
Look at the internal reference spec for these, they are OK, but not great compared to an external reference.
In theory it may have 16-bit or less ADC and a good wiring design and fast averaging.
