Hi there,
I'm currently attempting to build a soldering station that includes both a soldering iron and a heat gun. I began the project by designing a PCB and assembling it. After completing the assembly, I tested the majority of the functions successfully. However, I'm encountering an issue with reading the temperature from a MAX6675 using my MCU. When the MAX6675 is disconnected, I'm reading a value of 1023.75, but when I connect my soldering iron handle, the MAX chip reads 0ÂșC. Is this a common error associated with cheaper, potentially faulty components? i've tested reading the temperature with my multimeter and it reads well. i've checked all connections and proper setup. my max baudrate is of around 1.3MHz.. any ideas?
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0, 1);
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_12, 1);
lcd_discover();
lcd_init();
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_3, 1);
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
lcd_clear();
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_3, 0);
HAL_Delay(10);
HAL_SPI_Receive(&hspi1, buffer, 2, 1000);
raw = (buffer[0] <<
| buffer[1];
raw >>= 3;
raw2 = (float)raw * 0.25;
sprintf(str, "%.1f", raw2);
lcd_send_str(str);
HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_0);
HAL_Delay(350);
