Author Topic: Measuring Resistance in Circuit  (Read 3516 times)
Offline sdancer75Topic starter
  • Country: gr
« on: September 26, 2019, 06:46:57 pm »
Trying to measure an smd resistor in Circuit, I get a non constant value. Instead, the measurement  increases trying to reach the nominal value.
Out of the circuit it's ok.
So, the question is which components in the circuit cause that behavior to the resistor ?
« Last Edit: September 26, 2019, 07:12:35 pm by sdancer75 »
Offline soldar
Re: Measuring a Resistance in Circuit
« Reply #1 on: September 26, 2019, 07:02:04 pm »
Easy: Capacitor.
  • Country: gr
« Reply #2 on: September 26, 2019, 07:12:06 pm »
Yes of course but it makes me wonder because I test the component directly at the both ends, how can a capacitor influence the measurements in this case?
For example, at the attached schematic I will get a different value for my resistor if I measure it on the circuit?
« Last Edit: September 26, 2019, 07:17:08 pm by sdancer75 »
Offline Nerull
Re: Measuring Resistance in Circuit
« Reply #3 on: September 26, 2019, 07:43:48 pm »
If everything is in series you shouldn't see a difference, but few real life circuits are that simple.
Put your capacitor in parallel with the resistor and see what happens.
The following users thanked this post: sdancer75
Offline Zero999
  • 0999
« Reply #4 on: September 26, 2019, 07:45:37 pm »
Assuming no the capacitor is at 0V, you'll read the resistor value, when the resistance meter is initially connected to the circuit. After awhile, the capacitor will charge up and the reading will increase towards open circuit, or whatever the effective parallel resistance is. Unfortunately, it takes time to take a resistance reading, so you'll always read a slightly higher value, than expected.
Hint: very low voltages in the circuit can interfere with resistance measurements, because the meter injects a small current, measures the voltage and applies Ohm's law. This effect can be cancelled by noting the resistance value, reversing the meter's probes, recording the value again and take the average of the two readings, which will be close to the actual resistance value.
  • Country: gr
« Reply #5 on: September 27, 2019, 07:17:51 am »
Excellent I didn't know this. Thanks
Regards
Offline fourfathom
« Reply #6 on: September 27, 2019, 04:04:41 pm »
In this circuit the capacitor will still affect the resistance measurement because the battery is a very low-impedance element in the circuit.  Replace the battery with a short-circuit or very low-value resistor and you can see how the capacitor still has to charge up before the resistance measurement becomes stable.
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
Offline MosherIV
« Reply #7 on: September 27, 2019, 08:02:42 pm »
Semi conductors such as transistors, op-amps, logic gates, etc can also affect your measurements. If the voltage of the CC used to do resistance measurement exceeds 0.7V (or 0.3 for germainium) will turn on semi-conductors and affect the results.
Some ESR meters claim to use 0.3V as the test voltage and claim to be able to do in circuit measurement.  :palm:
Real circuits are generally too complicated to be able to do in circuit resistance or capacitance measurement. There are just too many other connected components that affect the result!
