Hello Everyone!
I have been googling around for a while and I just can't find a way to do this. I'm really sorry if I suck at searching, if it's the case, please do refer me to a link that might help.
Let me explain the situation. I have an old stereo set that has three parts, Radio/Amp, Record player and Tape/CD. The record player is connects to the amp/radio part in two different ways: throw an double RCA and with a priority Sony power connector. Since the record player doesn't work well at all, I decided to take it apart and see if I can harness the power that would normally feed to the record player unit in order to power a small Bluetooth receiver.
The voltage seems to be 12V, which can easily be transformed into 5V, but I have no idea how much current it can provide. Could you help me find out how to do this?
I have converted the 12V to 5V using a 470 and 330 ohms resistors and connected it to a micro usb cable and to the bluetooth receiver. It doesn't seem to receive enough power, when meassuring the current it seems to use around 50mamps. And when I connect it to a real usb on my laptop it uses 200.
Would a dc2dc step down converter allow for more current to be delivered? How can I tell what's the max current the stereo will give me??
Thank you very much for your help
