Sometimes you just don't need 50/100/250/500 or 1000 volts to test insulation properties for thin wires, fiddly connectors or other stuff that may need a bit more zap (or less) than a plain continuity/beeper etc.
It would be handy to vary the DC output from 0 volts to whatever the minimum first setting is on an insulation tester (which might be anything from 50v to 500v depending on make and model)
A separate interface/box with a potentiometer (and chicken head knob!) with + - input sockets would be ideal, with 2 breakout leads/male plugs going to the host meter
The short circuit current is usually anything from 1ma up to 10ma max on most of these zap testers
Can it be done simply/lazy with just a standard pot or a higher wattage wirewound type, or do I need a circuit/bug orgy ?
Or just get a pile of resistors and rotary switch, and settle for some fixed value attenuated output voltages ?
Any suggestions, thoughts, 'NO-o-o don't do it!'
or 'please explain again in English'
requests are welcome
