Ideal approach:
Because MIDI is a digital communication bus, it always connects to a microprocessor of some sort.
Use that processor to drive an LED, using any IO pin.
This way you can easily do things like stretch pulses, meaning you can turn the LED on for, say, 100ms when you send a single packet, so someone can actually see the LED. This is not the case if you just drive the LED with the data signals.
