Loading [MathJax]/extensions/Safe.js
Author Topic: minimum PS voltage and current for general use  (Read 3217 times)
Offline SnakeBiteTopic starter
  • Country: il
  • OBSESSED MODDER
« on: November 28, 2010, 08:47:25 am »
Hello,
i want to buy a bench PS soon, but i don't know what is the minimum recommanded voltage and current that i sould buy.
i almost sure i need more that 12v because a lot of electronics components works with this voltage.
i thought about a TDK-lamda LQ-531  with 20v and 8.6A what to do think? is it enough?
thanks
Ido
Ido Aricha , Israel.
Offline arcom
  • Country: hr
    • Arc's Lab
Re: minimum PS voltage and current for general use
« Reply #1 on: November 28, 2010, 09:12:10 am »
That depends on your definition of "general use". Someone who works with opamps on a daily basis requires a dual 0-15V PSU whereas someone who works mostly with digital logic requires stable 3,3/5V PSU.
0-25V @ 2A should cover 99% of power requirements for most hobby work.
To be on a safe side, dual 0-25/30V @ 3A is most popular choice if you can afford it.
  • Country: il
  • OBSESSED MODDER
« Reply #2 on: November 28, 2010, 10:54:35 am »
which one of the lambda series will be best for me:
i can't decide between the LQ-531(20V @ 8.6A) and the LQ-532 (40V @5A)
http://www.teknetelectronics.com/DataSheet/Lambda/Lambd_LQSeries23956.pdf
CAN YOU HELP ME?
« Last Edit: November 28, 2010, 12:33:34 pm by SnakeBite »
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #3 on: November 28, 2010, 01:46:25 pm »
Hi
You asked this question on another thread before I recall.  Lambda is a top notch, and expensive PSU.  These are great for professional work when you really have these going everyday; then you also compete with the likes of Agilent's PSU.
For hobbyist use they are overkill.
Generally, up to 25-30V at 3A is fine, these are the upper end for used on analog designs with op amps, and for most needs, you need a dual.  So you need either a single dual supply or two 30V supplies you can use together when you need it.
I prefer 2 separate, so if one blows, you still have the other working.
Hello,
thanks
Ido
Best Wishes,
 Saturation
  • Country: il
  • OBSESSED MODDER
« Reply #4 on: November 28, 2010, 05:10:19 pm »
I know it's OVERKILL that why i want it!  i'm a professional on bringing the top marker product at very affordable prices. look at my other posts...
for example : i got FLUKE 87V in 180 $ with shipping included to Israel, instead of 350$ + shipping. i also got the PACE MBT 250 in 130$ shipping included instead of 1200$ + shipping.
and so on....
got the point  ;D
Ido
« Last Edit: December 25, 2010, 09:01:06 pm by SnakeBite »
Offline Psi
« Reply #5 on: November 29, 2010, 11:32:06 am »
Love my lambda MML400, got it for NZ$100 secondhand.
It's not really a lap psu tho, no setable current limit. I just use it when i need high voltage or high current that my normal lab psu cant do.
It came with 4 isolated modules so there's a huge number of ways to connect them up for anything from 2V @ 25A to 70V at 6A
« Last Edit: November 29, 2010, 11:34:49 am by Psi »
