Author Topic: Mosfet gets heated up at 5A or above.  (Read 2012 times)
Offline Vindhyachal.taknikiTopic starter
« on: February 19, 2016, 02:11:40 pm »
1. I have designed a circuit using TI's bq24650. Schemtaic & gerbers are attached. (Part of both are removed, only I have shown is high current path & mosfet).
2. I have to operate circuit at 10A. Problem is Mosfet gets too hot at 5A or above even after 2 min of operation. Also Diode D1 PDS1040 gets heated up, but they are not very hot.
3. Actual circuit has only one mosfet but it was rated for lesser current. So I have used 2 in parallel in my circuit. What could be issue with the circuit, are track length too short. I have removed solder msak layer from high current path as in gerbers you can check. Also while soldering I have placed a thick solder on these exposed tracks. Mosfet has high current rating as you can check in mosfet datasheet.
Offline mmagin
Re: Mosfet gets heated up at 5A or above.
« Reply #1 on: February 19, 2016, 11:18:39 pm »
Is the inductor saturating?
Does the BQ24650 have enough gate drive that the mosfets are switching hard and not spending time in the linear region?
Offline nour
  • Country: sa
  • calm down, it is just a smoked oPamP!
« Reply #2 on: February 20, 2016, 12:26:58 am »
I am not expert but if the gate didn't get enough voltage to switch fully  on I think it would be a problem, because the Rds on state wouldn't reach its minimum which will cause the transistor to get hotter  at higher current :-//
if what I have wrote doesn't make sense for you or you think there is something wrong, please correct me, I am still beginner and what I know probably less than what you know
« Reply #3 on: February 20, 2016, 02:30:51 pm »
No, inductor is not saturating. It is rated for 32A sat.
Max input voltage is 21V.
Are these mosfet capabple of handle this current or some thing wrong in designing layout around these mosfets
Offline mmagin
« Reply #4 on: February 20, 2016, 03:02:47 pm »
Hmm.  Assuming the mosfets are being driven cleanly, looking at the gerbers, you probably want better heat conductivity from the drain pads of those mosfets.  As it is, you have the thermal relief (which makes it easier to hand solder).  You probably want to eliminate that and have some thermal vias to copper on the other side.  This kind of package is heavily reliant on those drain connections for thermal conductivity.
A look at the waveform between the S1/D2 node and ground on a scope might clarify whether the mosfets are switching as expected -- don't forget that the connections need to be really short, including the ground lead.
