Lowering the specs is out of question (I thought about it before), originally I wanted something crazy like 50v/5A or so, but 20v/2A is nice and more than good enough for most people.
The -1 V can come from the negative side of the isolated supply. Depending on the diode used it might be directly the negative supply, or a divider to GND.
Pfff I misunderstood you there! I thought the output of Q2 not the base! the base is before the 0.1R shunt which is effectively ground. So yeah, from the isolated supply with a simple divider! resistor tolerance won't be a problem since it is not needed to be that accurate -1v.
The oscillation frequency depends a little on the filter used. I got something like a 10-50 kHz superimposed to the output when the SMPS loop is oscillating.
Well, I tried to figure out what that means and this is the result:
This is when it is 20v with 2A (10R load).
I zoomed on the output voltage and it is like this, I noticed that there are spikes in the waveform that are not like the rest of it. I know from some videos I watched that this shouldn't exist, the correct thing is a uniform clean waveform... thus I considered it to be the thing you said about 10-50KHz stuff. Is it correct?
Now for a closer look:
the image is for the output voltage but zoomed and focused on it when it is stable not in the ramping up stage. I measured the frequency of the blue one (red one is a little shorter on its zenith than the blue) and it is around 11.1K or something (don't remember correctly). Is this what you meant?
Now, you said lower voltages are good and could be a final circuit for them... I tried 5v to see the exact way I did with 20v and this was the close look on the waveform:
I guessed it is correct since the waveform is clean and let's say "homogeneous" unlike before! the ripple here is natural I guess since it is zoomed a lot and there must be something like this.
___
Is my understanding correct here? I used my mind to think of what you said and I hope I learned something correct!
how did you know the loop was oscillating? I mean is it from the waveforms like the ones I posted?
___
If my understanding and analysis is correct, then what means should be taken to fix the thing? taking the feedback from before all filtering? or make more filtering?
