You are messing with the datasheets; you don't have the parameters of the VO3150 but of the UCC27424.
Stupid mistake is a reflection of the state of my brain at the moment
What a tool. There is no hope for me!
Anyway, i'll take a look at the correct datasheet.
You're right; the FET is voltage controlled, since its gate is isolated from the conducting channel, it acts like a capacitor; to build up a voltage in a cap, there has to flow a current - the higher this current is, the faster you reach a certain voltage.
So, if you drive a FET directly from a uC which sinks or sources maybe 25mA, it can take a considerable time to get the gate of high power FET charged and conducting - in other words - when using a FET driver, the parameter of sink- and sourceable current tells you, how fast you can switch the FET on and off - via I = dQ/dt
I will spend some time looking at your coulombs over time equation, to try to get a better general understanding of it, as it's another fundamental concept I need to understand in the future and add it to my various personal documentation folders.
0,5A for a driver is not such a great parameter; there are drivers, which can sink and source several Amps, but it's surely better than your setup with a common opto or directly driven by a I/O-pin of a uC
Indeed and as I said, PWM fast switching is not a Must, so any improvement in this area for my own education I am happy with at this point and I really was more concerned with the isolation so I am happy that this is as you said "surely better than your setup with a common opto or directly driven by a I/O-pin of a uC".
I have come back to electronics a year or so ago after many years away and I have really only been dealing with the digital stuff for my own amusement. More analog base circuits and the many fundamentals, principles, laws, algebra etc can not be all learned in a week.
I recently purchased
The Art of Electronics by Thomas Hayes book which has been a pretty great book so far and I am also following a Udemy course by Andre LaMothe
Crash Course Electronics and PCB Design which is 88hrs long and has also been very useful. At the same time I am trying to build this project which is quite a bit above my current ability level for my Father. With this in mind I appreciate all the time and advice that has been given to this 48 year old student
I am trying hard, but also a bit
'trying' at times too
Paul
