Author Topic: Motorcycle dash button failed  (Read 3098 times)
Offline VariousTopic starter
« on: November 10, 2019, 07:30:07 pm »
I am new to electronics, so please excuse any errors and feel free to point me in the right direction!
I have a 7 year old motorcycle with an electronic (LCD?) speedometer and buttons for switching between displays, but one button has stopped working. This is a known failure for this dash but it seems that no owners have been able to fix the problem and manufacturer replacements also fail. I am trying to understand the failure and then see whether a repair can be made, the part is very expensive to replace!
There is a theory among some owners that UK bikes suffer the failure more than American bikes, maybe the problem is associated with climate and therefore corrosion?
I have removed the dash from the bike and removed the workings from the outer casing for inspection.
I carried out a continuity test on the switch to see whether it works, and it seems OK.
I can see what looks like corrosion on the PCB trace, but I would like any feedback on whether this looks like the problem.
The PCB is printed with 'NS 06901'.
I will try to attach some photos to show you what I can see.
So...
Do you agree the problem seems to be corrosion of the PCB trace?
Is it realistic to make a repair to the trace?
To get access to the trace, I think I need to remove the PCD display, but this seems to mean removing the solder for all of the pins (see photo), am I correct?
Thanks
Matt
Offline ataradov
    • Personal site
Re: Motorcycle dash button failed
« Reply #1 on: November 10, 2019, 07:59:30 pm »
It is corrosion, and the repair is very possible. But it looks like the corrosion is around something that was not soldered before. Where is the actual button? Where do those holes go to?
Alex
« Reply #2 on: November 10, 2019, 08:10:54 pm »
That is good news!
Photos attached showing both sides of the PCB to help give an idea of what goes where.
Thanks
Offline ataradov
    • Personal site
« Reply #3 on: November 10, 2019, 08:17:11 pm »
Ah, ok, this is (was) a plated through hole. This is a trivial repair for someone moderately skilled with a soldering iron.
All you need to do is scrape the green solder mask from the trace on one side and on the other side after the corroded part. Then run a wire though the hole and solder it on both sides.
Alternatively you may trace where the trace goes after it goes under the plastic. It is likely that it goes to the big black chip, so  it must jump sides one more time. If you trace where it appears on the same side as the button solder points, you can just solder the jumper wire there right from the button.
It is a good idea to clean the corrosion in either case.
Find literally any electronics repair shop and they will fix this in 10 minutes.
Alex
« Reply #4 on: November 10, 2019, 08:45:53 pm »
Thanks!
I will try to trace where it goes; the position of the corrosion makes it very awkward to reach because it is almost behind the plastic and I think that removing it would be quite difficult (for me!).
I will look for an electronic repair shop to make the repair, but I would like to be able to repair it myself too. I might go and practise the repair on an old PCB to see whether my skill is as high as 'moderate'.
Thanks again.
Offline techman-001
  • Electronics technician for the last 50 years
    • Mecrisp Stellaris Unofficial UserDoc
« Reply #5 on: November 10, 2019, 11:42:48 pm »
Thanks!
Thanks again.
Take your time and remember to NEVER FORCE ANYTHING or you'll just wreck the pcb. If you're stuck at some point, walk away from it until you have a clear new approach to try.
Use "solder wick" to try and get the LCD pins free of the pcb but it won't be easy. If you can't wiggle each pin easily in the hole when you've removed the solder but you prise up the display anyway you'll probably pull the VIA guts out of the board and lift copper tracks   ... don't ask me how I know this.
Once you have repaired the board and it all works, then you have to figure out a solution to stop the water getting into the display in the first place. Is it condensation or rain ?
If it's rain, it may be a good idea to make up a sensor to detect water in the display while you try your solution out because this will probably be the really hard part to monitor over a period of time.
Offline ataradov
    • Personal site
« Reply #6 on: November 10, 2019, 11:59:06 pm »
I would not remove the LCD. There is no need to. Everything you need for a fix is accessible with LCD in place.
Alex
Offline techman-001
« Reply #7 on: November 11, 2019, 12:27:44 am »
I think it may have to come off because:
1) The corroded area is under the plastic LCD mount and is much smaller than the magnified view in the pictures. Access may be very hard and promote pcb damage.
2) The button is within the plastic LCD mount and may not come off (if damaged by water) without the LCD being removed.
3) If water is getting inside the cluster there could be more corrosion under the LCD. Of course if the OP can clearly see there is no problem under the LCD then as you say, there may be no need to remove it.
Offline schmitt trigger
  • Country: mx
« Reply #8 on: November 11, 2019, 12:33:58 am »
I am surprised that the board is not conformally coated.
The motorcycle environment is harsh. Is not only plain moisture ingress, but that the road may still contain salts used during the winter season.
Plus many owners pressure-wash their bikes, and you'll have soaps and other chemicals.
« Reply #9 on: November 11, 2019, 10:39:56 am »
Having looked at it carefully, I can see no other corrosion at all. I have contacted a Tech Repair company to see whether they can repair it. I'd rather practise my skills on something an awful lot cheaper to replace!
Other owners with the same problem have also expressed surprise and disappointment that the unit is not better protected.
Offline techman-001
« Reply #10 on: November 11, 2019, 11:07:48 am »
Conformal coating isn't all win-win. For instance if there is a electronics failure, the board can be virtually un-repairable depending on how tough that coating is.
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #11 on: November 11, 2019, 11:18:36 am »
You can fix that with a piece of 30 AWG wire wrapping wire (google "ok 30 awg kynar").
Offline AndyC_772
« Reply #12 on: November 11, 2019, 11:41:53 am »
Don't touch the LCD pins; I can virtually guarantee that you'll do more harm than good unless you're already experienced in this type of PCB rework.
Personally I'd start with an abrasive fibreglass pencil. Use it to remove the corrosion and the solder mask on the affected trace(s), so you can clearly see where any breaks are. It'll also leave a clean, oxide free surface that you can solder too.
Bridge any breaks with solid core wire as advised above. Even if it's just a hairline crack, using copper wire (which is ductile and not brittle) will give a longer lasting repair than just a solder bridge, which can easily fracture under vibration.
Test before reassembly, obviously. Once you're happy that it's working, it would do no harm to coat the area with a protective layer - though it could be argued that the problem is water getting in at all, not that there's any particular issue with that specific part of the PCB.
  • Country: mx
« Reply #13 on: November 11, 2019, 08:11:29 pm »
Engineering is the art and science of compromise of conflicting requirements.
It is true that a conformally coated board may become un-repairable, but it would be better that the board does not become defective due to environmental factors.
Clearly a motorcycle environment qualifies as a challenging enviroment.
But again, when one is designing a product, and a business case is being made, these decisions are made.
Offline m3vuv
« Reply #14 on: November 11, 2019, 08:41:47 pm »
what make and model bike is it?
« Reply #15 on: November 17, 2019, 09:13:53 am »
Don't touch the LCD pins; I can virtually guarantee that you'll do more harm than good unless you're already experienced in this type of PCB rework./quote]
I hear you loud and clear! I'll give up before I take the soldering iron to those pins!
Yamaha Super Tenere XT1200Z.
I found a local tech repair company who went to the bother of setting up a website but don't answer the phone or reply to emails, so I'm back here!
In the attached photo there is a copper ring, after cleaning it up I can't get continuity across it from one side of the board to the other. Can somebody explain this component to me including its name please? To me, it looks like a copper 'rivet' which should have continuity across the board. There is another switch with the same setup and I do get continuity across that one.
« Reply #16 on: November 17, 2019, 10:40:45 am »
Now that I have re-read the advice given to me previously, it is starting to make sense.
I have now found where the trace runs to (by using a continuity test) and proved it by inserting a wire between the two points as shown in the photo. I have tested this on the bike and it works!
1. Should I now be looking to solder a wire permanently in place to make the same link as the temporary wire shown?
2. Is the information in this video by Manchester University good?
4. Is it likely that this connection could affect another function? The bike obviously has other functions, an alarm, immobiliser etc so should I test the different functions before making the repair permanent?
Thanks for your help.
Offline AndyC_772
« Reply #17 on: November 17, 2019, 10:45:51 am »
The feature you've circled looks like a through via, ie. a plated-through hole which forms a connection from one side of the board to the other. If it's a multi-layer board, it could connect to internal layers too.
If you don't measure continuity from one side of the board to the other, then that's good insofar as it means you've located an electrical fault that can be fixed. It may not be the only one, but you have to start somewhere.
Clean up both sides of it with a mild abrasive - emphasis on the "mild" - so you have clean, shiny copper exposed. Poke a short length of solid core wire through the hole and solder it on both sides, job done.
Offline AndyC_772
« Reply #18 on: November 17, 2019, 10:51:28 am »
ps. the photo you've attached of a wire link is horrible.
Hanging a wire that fat and heavy off a couple of tiny vias is just asking for them to be ripped off the board under vibration, and that'll leave the board in a state which is much harder to repair. All those spare copper strands waving about in the breeze won't do any good if they touch anything else either; at the very, very least they should have been trimmed back to the insulation.
If that's the repair you need to do, use 30AWG solid core wire as advised above, and tack it to the PCB with superglue so it doesn't flap about. A couple of tiny dots are all you need, don't go mad with the glue, and don't get any on the solder joints just in case you ever need to repair them.
« Last Edit: November 17, 2019, 10:53:03 am by AndyC_772 »
« Reply #19 on: November 17, 2019, 11:26:26 am »
Ha ha, sorry, that was just a bit of wire I had laying around and used it to test that I had found the correct parts. It is going in the bin soon!
So I can just superglue the new wire in place??? Brilliant!
I have read that the areas where I removed the mask should be re-coated with epoxy, is this correct?
Thanks again
« Reply #20 on: November 17, 2019, 11:37:59 am »
You didn't mean I could replace the solder with glue did you?! You meant glue it to the PCB to stop it flapping about after it has been soldered at the ends.
Sorry, this is in the 'Beginners' section for a reason!
Offline Rerouter
« Reply #21 on: November 17, 2019, 11:43:58 am »
correct, superglue to support the wire after it is normally soldered (soldering near superglue will sting your eyes and nose worse than you can imagine)
To prevent the weak vias from possibly being damaged by the weight of the wire as the bike will go over bumps etc,
« Reply #22 on: November 19, 2019, 03:52:20 pm »
Well, it's fixed!
No doubt the experts would have done a lot better job, but for me it has been interesting and rewarding. It has also saved a whole lot of money and prevented a usable component form being thrown away.
The photo shows the wire I soldered between the two points.
Thank you to everybody who helped me.
The following users thanked this post: GeorgeOfTheJungle, Mr. Scram
Offline Mr. Scram
  • Display aficionado
« Reply #23 on: November 19, 2019, 04:19:30 pm »
Well, it's fixed!
Thanks for reporting back. That's definitely not a terrible repair. It looks like it may be a bit susceptible to vibration in its current form but now you know what to do! Maybe you could fixate the wire with some hot glue. That would also allow you to remove it all later on.
  • Country: tr
« Reply #24 on: November 19, 2019, 04:36:04 pm »
It's not horrible but it isn't perfect either: You should have left less exposed wire at the ends... I would put a bit of kapton tape under the exposed wires at both ends. That, or a drop of thermoplastic just to be sure it can't touch the pcb traces underneath.
Offline Mr. Scram
« Reply #25 on: November 19, 2019, 04:52:31 pm »
Hot glue!  ;D
  • Country: tr
« Reply #26 on: November 19, 2019, 04:58:23 pm »
I mean... hot glue!  :)
The following users thanked this post: Mr. Scram
Offline AndyC_772
« Reply #27 on: November 19, 2019, 08:47:29 pm »
I see the recommended dot of super glue at the bottom end, so no issues there.
I can't see one at the other end, and if there really isn't one, it would do no harm to add it even if it gets onto other components.
That aside, I'd call it a perfectly serviceable repair, and I've seen much, much worse. Nice job!
« Reply #28 on: November 19, 2019, 11:15:59 pm »
The superglue is indeed there at one end. I didn't put it elsewhere because I would have been gluing directly onto a solder joint or a trace - is it OK to glue to those?
But thanks for the feedback anyway, much appreciated. There's so much bare wire at the ends because I wasn't sure how close it could be without melting and causing solder problems. So definitely a 'beginner' thing on my part.
Offline ataradov
    • Personal site
« Reply #29 on: November 19, 2019, 11:43:32 pm »
Yes, it is fine. Superglue is not conductive.
But I would also put a few glue dots along the wire as well. Vibrations will break the cantilevered mass. They may not seem like much, but there are a lot of them and they are consistent :)
It does not have to be superglue. Hot glue would work as well.
Alex
