I need help/reviewing with the design a PCB power supply.
I'm designing a board (or a set of boards) to automate the management of a pool.
I have the following 'blocks' :
- An ESP32 SoC - 3.3V
- A pH & ORP probe "reader" board - low drift 5V
- Relays to control 230V pumps - independent 5V (connection to ESP32 outputs is made through optocouplers)
- A DS18B20 temperature probe - 5V
The 5V for the pH/ORP probes reading is done using one of two outputs of a LT6658 (low drift, high accuracy power supply). The other output will bes used to power the temperature probe.
Board(s) general power supply is AC power (220-230V).
I imagine the following combination:
- 220V - HLK-PM09 - 9V - LT6658 - 5V - pH/ORP probes (output 1) & DS18B20 probe (output 2)
- 220V - HLK-PM01 - 5V - relays
? - 3.3V - ESP32
The HLK-PM
xx parts will be equiped with fuses and varistors for safety.
What do you think of this setting? Regarding the ESP32 power supply, is it best to use a 3.3V regulator (such as AMS1117) connected on the 9V supply, or else to use an additional dedicated HLK-PM03?
Thanks a lot for you help!
