First, we need to decide if this is a hobby or an attempt at a career change. If you plan to do EE as a career, strap in for a 5 years of education and the AoE isn't nearly sufficient.
For a hobby, reading a book isn't particularly useful other than to learn where in the book certain concepts are discussed. The only way to learn the material is through practice. Design something and analyze the heck out of it. Design the circuit, simulate the circuit with LTspice and then build/measure the circuit on a breadboard. Keep lots of notes. You can use the lab experiments from the book. Don't count on getting the same answer. Two reasons, tolerances and the possibility that the book is wrong. Believe what you measure, not what you read.
Take the simple battery/resistor networks, analyze them with Kirchhoff's Laws, simulate them and measure the results with LTspice and then build the network and measure everything. The answers won't agree due to tolerances but you should be close enough. I posted the wxMaxima solution to KVL and KCL for a specific resistor question but you can rip the code and use it for all of your work
https://www.eevblog.com/forum/beginners/kvl-and-kcl-equations/All of this can be done with a simple DMM. What test equipment do you have access to? You won't go far in the time domain without a scope or in the frequency domain without a way to create Bode' Plots or FFTs.
Next up would be RC networks in both the time and frequency domains. You want to truly understand the charge and discharge equations for an RC circuit in the time domain and you also need to understand how they work as a filter in the frequency domain. This is where things start to get interesting. Resistor networks are boring...
Progress through RLC circuits, again in both time and frequency domains.
Now you can start playing with things like the common emitter amplifier and the CE amplifier with emitter degeneration (see W2AEW's video on transistor amplifiers). Get the transistor datasheet, be overwhelmed by all the numbers, each of which limits how you can use the device, and see what values you actually get on the breadboard.
Then learn how to use the transistor as a simple switch to light an LED, for example, from a uC output pin. Learn how to calculate the LED resistor from Kirchhoff's Laws. Learn how to calculate the base resistor from the collector current and hFE.
At this point, you're at about the end of the first year of EE. Maybe not quite... From here on, things get a little more involved.
Try the Khan Academy Electrical Engineering videos and Digilent's
True Real Analog lectures. At this point, the math is going to get intense.
I asked above about what test equipment you had access to. If the answer is "none", you might be in luck.
If I were starting from scratch, knowing what I know now, 50 years after starting college, I would buy the Analog Discovery 2. I know, a lot of people scoff at this but they're making a big mistake. For $279, you get a decent dual channel scope and a dual channel Arbitrary Waveform Generator along with a dual power supply and 16 bits of bidirectional digital ports. Before you blow it off, download the Waveforms software and play with the Demo device. This is the most amazing educational tool in the world. It doesn't have the knobs and dials of a bench full of equipment but it is targeted specifically at students. It is also useful for really old guys who have a pretty full bench of equipment.
You can do a Bode' Plot of a filter using the built-in AWG to provide the input signal and the scope channels to display the phase and frequency response. This is amazingly hard to do with a bench scope and signal generator. If you want the FFT of a signal, say a square wave, the AD2 will provide the waveform and perform the entire analysis. This capability exists, to some extent, on modern DSOs.
Run the Spectrum gadget in demo mode, select a start frequency of 0 Hz and an end frequency of 10 kHz and you will see the FFT for some magical 1 kHz square wave. Play with all of the gadgets and see what you think.
Did I mention that once you get past the RC and RLC circuits, the math gets more involved? Frankly, the equations for RLC circuits are pretty complex but they are well understood so it's not often that students really need Differential Equations to solve them. Get real familiar with wxMaxima. I also highly recommend MATLAB and the Personal license isn't terribly expensive but it isn't free. Octave is a perfectly good substitute and it's free.
Just build stuff! Have fun!
