This is used for antenna connection in an Asus WiFi router.
Male SMA RP-SMA female, ground is soldered to PCB, signal wire is routed into it from the rear, and the coax shield appears to be crimped, by the shape of it.
Is there a searchable type/model identificator for it?
PCB footprint and the coax cable:
