Author Topic: Need Power Supply for macbook logic board repair  (Read 1261 times)
Offline Vietk123Topic starter
« on: August 19, 2016, 06:11:32 am »
I am new to the forum and find a lot of useful info here thanks all. I am looking for a bench power supply. I am mainly focusing on macbook logic board repair and iphone logic board testing and repair. What is a decent brand bench power supply should I be looking for? My budget is around 150-200 if need to be. What voltage and amp should i be looking for? I know this question might be answer already have I did search youtube and google and this forum but get mix result. I would love some feed back of you guys thanks in advanced and good to learn from you all.
Offline jeroen79
Re: Need Power Supply for macbook logic board repair
« Reply #1 on: August 19, 2016, 09:06:18 am »
The required volts and amps would be dictated by your work.
What voltages are used on the apple logic board and how much current does each line use?
Are you going to isolate parts so you only need low current or will you have to power everything on the same powerline?
