I'm on experiment 10 in the Make Electronics book. I understand what's going on with the transistor being used as a switch, but I'm confused by the mA readings I'm getting. There are suppose to be 3 resistors in the circuit, I'm using 4 (two in series a 217, and 463 ohm) to get the required 680 ohms. There is then another 9,870ohm, and a 217 ohm. for a total resistance of 10767 ohms. Using Ohms law, that would come out to about .0011 amps or 1.11 mA's correct? My circuit actually is drawing about 11.06 mA's. Is that because the transistor is actually amplifying the current? This is all based on 12 volt input.
