Why not take the AN8008 apart, there may be a bad contact in the rotary switch.
already tried, the contacts seems ok, but when i switch to resistance it reads hz instead, and it doesnt allow me to switch to the secondary function of hz, so i assume is some kind of software issue (?)
The Fluke brand of DMM seem to be quite good quality, but at a redicilous pricepoint, so I won't even buy one even if they put a reasonably priced version on the market.
If I was looking around for a quality meter, then it would very likely be a Brymen meter. Qualtity is very comparable with that other brand,but you can buy two for the price of one of that other brand.
wow, you are SO right, like
this BM 867s. i found it for 160€ and it has so many functions that im not sure i know how to use them all.
also, by checking brymen catalog, if i avoid the electrician multimeters (the most basic ones) they all cost around 160€ or more.
the only two drawbacks that has (for me) are the somewhat low diode test voltage (2v) and the 9v battery instead of 2xAAA, which are minor things.
what do you think about it?
