Hello Folks, New member here. So, as the title says, I recently acquired a Vintage Simpson 260 series 3, in which all functions are working except AC, I'm wondering if anyone else has run into the same problem with this model?--- Simpson manufactured a whole slew of variations of the 260 VOM meter in several different series. Mine happens to be a series 3.
But I digress, I'm going on day 3 troubleshooting . The laundry list is long of every thing I've done so far, so I wish not to bore anyone by going into an endless rant right out the gate so to speak. Just a small snippet of what I've done so far --- Checked all resistance values within the AC measurement circuits, all are either close or right on spec. Replaced 2 geranium diodes in the modified rectifier bridge circuit, D1 and D2 in the schematic ,also, resistors R29 and R30. These 4 components make up the full wave bridge ( though not a conventional one ). After the current finishes running through all these series resistances and trimmer pots what's left at the rectifier bridge when on the 250VAC scale, is something like .648mV. From research, should be around 1.2mV. Maybe I can try changing out all the series multiplier resistors ? IDK
