Ok that would make sense. But the max input of the converter is 90V. I only have a 60V power supply, and at 60V the voltage at the gate is 21V. It seems to be rising linear to that point. So could it be a MOSFET with a higher Vgs then?
There is no reason to drive most MOSFETs with such high voltage, even if they do have 30V Vgs max.
Perhaps it was a mistake at production and 1N4148 was used instead of zener... Who knows?
Do you know the part number of used MOSFET?
If so it would have been easier to just adjust the voltage divider right?
Divider should be chosen so that MOSFET is fully open (e.g. Vgs=10V) at min input voltage.
