I had taken out the pot for my Denon DAP-5500 as it was scratchy and would sometimes drop a channel til I would work it and would come back for few days. Decided I had time today and would just desolder from board and disassemble and clean properly. My only issue is I forgot to take a pic of the orientation of each of the white wiper parts and how they were aligned. Due to the shape of the rod and the cutouts on each wiper piece, they can only go one of two ways. I did have frame of mind right after I took off the first (back) and I know how that last white wiper was orientated, note the main shaft is turned to "max volume" in that photo. Does anyone know if the other three wipers are in same orientation or if not which way each should be orientated on shaft when reassembling from front to back?
This is the photo of the pot with the back taken off rear and shaft turned all way to "max"
Also one of everything for reference
