I think there are several distinct aspects to this.
1. Panel size versus charge controller versus battery sizes.
2. Full system load cycle sizing.
For the later, as I live at 55*N in a country were we have about 150 words for rain and cloud.... I tend to go 10x load for the panels, ie, expecting 10% output averaged over 24 hours and probably 2 weeks storage if it's going to make winter. I do see short term road signs with 100W panels, but they have a trailer full of 12V lead acids, last one I got a peeking to had 8 100Ah batteries.
In this case, there is no fixed load. I would like to slowly progress to running a lot more DC stuff off it. I also hope to add a battery charger on a smart plug to kick in if the battery gets low, so that the load is un-interrupted, when effectively switching back to mains.
It is the former "Panel size" versus what I have for a charge controller. It is physically fused at 10Amps. I plan a 40A one for later.
I am taking the point, I think?, while for an hour either side of noon on a warm sunny day it might be significantly limited at 10A when it could produce 30A, but... later when the sun or off angle or there is thin cloud the 300W panel will still be able to produce those 10A for much more of the day than say a 150W panel, which might hit the 10A at noon, but barely make 5A outside of that.
The plan is to go with a rail setup for 3x300W panels. Initially install 1. Once that is out of the way, I can choose if the budget goes on new batteries or new charge controller.
Longer term, if it gets to storing a usable few Kwh, I might put an inverter on it and run a few office plugs off it.
