Author Topic: On indicator  (Read 3677 times)
Offline jj5Topic starter
  • Still learning about electronics...
    • In The Lab With Jay Jay
On indicator
« on: February 10, 2023, 02:02:04 am »
Hi there. Sorry for this basic question. I'm taking the power board out of an old OG Xbox and installing it in a separate enclosure so I can use it for testing Xbox motherboards. I will be providing a switch on the front panel of the enclosure to connect the 240 V AC mains power. What I'd like to do is wire in an indicator light that turns on when the device is powered. But I'm not sure how to go about that. What I'd like is a component I can wire in series with the power switch which will just work. But maybe that's not the way to go about this? I'm not sure. What sort of power-on indicator should I buy and how should I connect it to the internal wiring and the power switch? Thanks in advance.
Hi, I'm Jay Jay. I'm a computer programmer from the Blue Mountains, NSW, Australia. I have a beginner-friendly electronics video blog on YouTube: In The Lab With Jay Jay and I blog at blog.jj5.net.
Offline themadhippy
Re: On indicator
« Reply #1 on: February 10, 2023, 02:14:32 am »
use an illuminated switch,1 less hole to make,and if its double pole simple to wire
Re: On indicator
« Reply #2 on: February 10, 2023, 02:34:47 am »
Thanks for the suggestion. Would one of these work?
I'd still like an answer to my original question so I can learn how it might work.
Offline themadhippy
Re: On indicator
« Reply #3 on: February 10, 2023, 03:22:37 am »
wouldn't   trust it,something like https://au.element14.com/molveno/sx8211881g110000/rocker-switch-dpst-20a-250v-panel/dp/3531798 would be a safer choice.As for the original question the indicator is normal wired in parallel with the load so the 2 wires for the indicator goto the same points  the mains supply for your power board is connected to,just make sure its voltage rating is the same .
The following users thanked this post: jj5
Offline Whales
    • Halestrom
Re: On indicator
« Reply #4 on: February 10, 2023, 03:33:15 am »
You do not want to wire this in series.  You want to wire the light in parallel with the load (console).  Otherwise the voltage going to the console will be lower than 220V (due to the drop across the bulb).
This will tell you that 220V is present, but it will not tell you how much current the console is pulling.  For that you will need a current clampmeter.  This might be a useful diagnostic tool to have anyway (if you're repairing lots of consoles).
Re: On indicator
« Reply #5 on: February 10, 2023, 04:05:19 am »
I found an answer to my question with a schematic over here: LED Power indicator for 220v AC mains.
Offline SL4P
  • There's more value if you figure it out yourself!
Re: On indicator
« Reply #6 on: February 10, 2023, 06:12:33 am »
Just remember you’re playing with mains.
Around a second of adequate contact with your skin might render the LED unnecessary.
Don't ask a question if you aren't willing to listen to the answer.
Re: On indicator
« Reply #7 on: February 10, 2023, 06:25:57 am »
How could I forget? I have to say I'm very nervous about this project. I watched the following video and the presenter seemed very cavalier about playing with mains power.
Re: On indicator
« Reply #8 on: February 10, 2023, 08:49:41 am »
So I've been doing some research and I've come up with the following schematic (based on the info from the YouTube video I referenced above) but I'm not sure what value to use for R1? That's just there to bleed out C1, so maybe 100K?
Offline mariush
Re: On indicator
« Reply #9 on: February 10, 2023, 09:19:41 am »
A bridge rectifier is overkill ... a single diode is enough. It will do half wave rectification and that's enough for a basic led... worst case scenario if you see some flickering, you can just add a small capacitor to smooth the voltage.
If you want, add a zener diode, which will cap the voltage to reasonable levels.
See for example this application note about such power supplies : https://ww1.microchip.com/downloads/en/AppNotes/00954A.pdf
You have right at the start a capacitive dropper circuit and at page 10 there's one with extra safety considerations.
Re: On indicator
« Reply #10 on: February 10, 2023, 09:21:14 am »
I discovered the W10G bridge rectifier, so figure I will use one of those. Not sure what value to use for R1 though?
Offline mariush
Re: On indicator
« Reply #11 on: February 10, 2023, 09:30:57 am »
Some high value , 470k-1meg
again, you don't need a bridge rectifier, a single diode is enough. but you do what you want.
Offline Whales
    • Halestrom
Re: On indicator
« Reply #12 on: February 10, 2023, 11:28:29 am »
Won't a capacitive dropper fail to work if you only have one diode?
Offline timenutgoblin
Re: On indicator
« Reply #13 on: February 12, 2023, 08:28:04 am »
I noticed that the O.P. has already started a new thread asking about a suitable AC voltage dropping capacitor, but I have a suggestion of my own. Perhaps it's too late, though.
I noticed that Jaycar have a transformer (MM-2002) with multiple output taps (6.3V, 7.5V, 8.5V and others) which could be used to directly drive a red LED (Vf =1.8V) or a pair of anti-parallel red LEDs. Using the 6.3V and 7.5V taps, it's possible to get 1.2V - 1.3V (RMS) which equates to approximately 1.8V peak across the red LED. There's no need for a current limiting resistor since the DC winding resistance between the secondary taps is probably enough. I should mention that the transformer is rated at 15VA which is obviously excessive for driving the LED, but the voltage taps are suitable, though.
Alternatively, it might be possible to use an NCP785A "wide input voltage range linear regulator" to output 3.3VDC to drive an LED up to a few mA. A current limiting resistor would be required to be connected between the output of the linear regulator and the LED.
Link to the Jaycar transformer:
https://www.jaycar.com.au/6-3-15v-15va-1a-multi-tapped-type-2155/p/MM2002
Link to the NCP785A datasheet:
https://www.onsemi.com/pdf/datasheet/ncp785a-d.pdf
There's also an EEVBlog discussion thread:
https://www.eevblog.com/forum/blog/eevblog-1285-how-to-do-design-by-inspection
Offline Zero999
  • 0999
Re: On indicator
« Reply #14 on: February 12, 2023, 09:23:01 am »
There are some pretty small surface mount bridge rectifiers. It might actually work out smaller, than using a single diode and capacitor.
https://docs.rs-online.com/c927/0900766b814bbf0c.pdf
Offline BillyO
Re: On indicator
« Reply #15 on: February 12, 2023, 04:17:18 pm »
Why are you putting the indicator light on the mains side?  I would put it on the LV side of the PS.  Then you just need a resistor and an LED.
Bill
Offline BeBuLamar
Re: On indicator
« Reply #16 on: February 12, 2023, 04:55:59 pm »
I would simply buy an indicator light that has the correct rated voltage in this case I guess it's 240VAC?
