Ok, thank you very much the below equations considering A,B,C,D and C = D
The updated solution is i have attached, the voltages are very high the opamp will saturate to 9V.
VA = 821.33V, VB = 902V, VD=861V, VC = 861V, Vout = 1723V.
I made LTspice and it matches with the results.
