There is, kinda, put in a 100k resistor from the + input to +5 and squeals and whistles and moans will b urs 2 hear.
With the resistor you'll always hear a tone, without the resistor you will always get it to work with some type of squeeze and make crappy sounds, and for free, mains power line hum modulated noises, like in the video linked.
Keep things simple, simply is not the ideal case here..crap circuit is tooooooo simple.
If you use an input to a CD4001 connected to a 8-in antenna or wire or a metal plate approx the same length and take the output of that same 4001 gate and feed it into the input of VCO you will have a real theremin that you can change sounds from over a very wide range and distance from the antenna.
You can make a good VCO from an op-amp or two as well, see attached
Hint CD4046 is a good VCO, but forget about the PLL, just the VCO section of this chip.
