Yes 10 Nos of Solar Panels
Also, I've found a 24V/30 Amp Solar Charge Regulator by Tata BP Solar. Unfortunately, I don't seem to understand the rating in it. The manufacturer is no longer in the Solar Business so can't ask them directly.
It only says 24V/30 Amp, and my confusion is:
- 24 V probably means 24V Battery. There is however, no mention of the solar input voltage range
- 30A is confusing though, does it mean load current or Solar input current?
- Can I connect 72 V (i.e. two solar panels in series) as the input? The current would be 13.6 Amps that way.
- How many such 72V Strings can I connect in parallel? Since the rated current output of each panel string would be 13.6 Amp, perhaps 2 such strings?? Still confused.
