1gsa/s oscilloscope can help me ?
i want to measure 2.5ns delay between pulse.
Probably the best bang for buck for your needs is the 2 ch 200MHz SDS1202X-E.
I know you're trying to be helpful but capturing a 100 MHz square wave with a 200 MHz analog bandwidth isn't going to be fun. Unless I misunderstood the thread starter and he/she really means milli Hertz, that is.
From the OP:
i want oscilloscope for high speed digital clock like 100mhz.
I'd take that to mean 100 MHz as I know of no 'high speed digital clock' that runs at milli hertz.
So many post here using the wrong units and we get sick/lazy about correcting them, but we should.
When there's enough info in a post so that's clear what is meant we can then make a recommendation.
Probing technique and the 2 signal sources will determine the accuracy of a '2.5ns delay between pulse' but all things being equal (probe connection and same signal source) the DSO mentioned is capable of such measurement.
As with many things that start to push the envelope of an instrument, operator skill needs to be up to the task.
If you can recommend a better instrument at a better price point, well please do.
