Author Topic: oscilloscope problem  (Read 340 times)
Offline mike_mikeTopic starter
« on: April 23, 2024, 04:59:24 am »
Hi! I recently bought a new oscilloscope upo1102cs from uni-t. It is working ok, until I connect it using utp cat5e cable to the router. On the same router is connected the pc. The wan cable that enters into the router is coming from the main router. I can easily access the oscilloscope from the pc, I can see the waveforms on the pc, but if I navigate in the menu of the oscilloscope webpage, after a while it appears again the login screen, and after I enter the username and password, it gives me a error and the oscilloscope freezes on the benchtop and it gives me a time out error on the pc.
What should I do ?
« Last Edit: April 23, 2024, 05:01:34 am by mike_mike »
Offline aliarifat794
  • Country: bd
Re: oscilloscope problem
« Reply #1 on: April 23, 2024, 07:45:17 am »
If possible, assign a static address to the oscilloscope.
Offline dcbrown73
« Reply #2 on: April 23, 2024, 11:21:34 pm »
If it's freezing up, I would check for firmware updates also.   It could be a known issue that is already resolved in firmware.
Why exactly do people feel I should have read their post before I responded?  As if that was necessary for me to get my point across.
