Author Topic: P to P measurements with an RMS meter?  (Read 1950 times)
Offline AxtmanTopic starter
« on: March 13, 2014, 03:48:04 am »
How can I measure peak to peak voltage with an RMS multimeter?
Offline w2aew
    • My YouTube Channel
Re: P to P measurements with an RMS meter?
« Reply #1 on: March 13, 2014, 12:14:48 pm »
The answer is - you really can't.  IF the signal you are measuring is a sinewave that is within the frequency range of your RMS voltmeter, then you can calculate the peak to peak value by multiplying the RMS voltage by 2.828.
FAE for Tektronix
Offline ConKbot
« Reply #2 on: March 13, 2014, 12:15:51 pm »
If its a sine wave youre measuring, mulitply by 2*sqrt(2), or 2.8284.  For RMS to Vpeak its RMS*sqrt(2) but since you want peak-peak, its 2x that.
If its not a sine wave, then make a voltage doubler,
(the transformer in the image is the AC source, substitute with whatever you want to measure) and add ~0.6 to 1V for the voltage dropped over the diodes. The drop would nominally be 1.4V for the 2 diodes, but with no load being drawn, then the Vf of the diodes will drop a lot.
Offline Wytnucls
« Reply #3 on: March 13, 2014, 12:25:31 pm »
Some true RMS multimeters have a 'Peak" feature, giving you peak to peak values.
Here is an example: (the 71B meter on the left was defective)
Offline ttp
« Reply #4 on: March 14, 2014, 05:45:13 am »
Nice to know, I got 71D.
