I have gathered all the needed parts to try starting the journey of etching my own PCB for the first time. I have few questions :
1. How careful should i be with the board that has etchant on it like can i clean the board in a metal sink after i take it out ?
If the sink is stainless steel, it will be OK. The action of ferric chloride and other etchants on SS is primarily due to the chloride under acidic conditions. Your products will contain no chloride. The salt, sodium bisulfate (NaHSO4) is somewhat acidic; however, it is also used as a food additive. Dissolved copper (e.g., Cu(I) and Cu(II) ) are somewhat more dangerous.
2. Is ok for sodium persuflate to get on wood, plastic ?
Plastic is generally pretty immune to it for short exposures. My main concern would be possible oxidation over long periods of some reactive plastics. Generally, I would not be concerned. It is shipped most likely in a plastic bottle, right? For wood, you might get more staining and oxidation. One of the precautions is that strong persulfate can ignite paper. However, your solutions will be in water and somewhat dilute, so staining would be my main concern.
3. Can i use a fabric to wipe drops of sodium persuflate and what should i do with it afterwards ?
See #2 answer
4. Can i leave the etchant in my etching tank ? As far as i can read i can, i just need to add more water that has evaporated but will it still work and so for how long ?
Yes, sodium persulfate is reasonably stable so long as there is nothing else in the tank that can be oxidized. As for how long exactly. I don't know. There are too many variables.
ALL of the above responses apply to sodium persulfate. Remember that once you etch your copper you will have copper sulfate also present. That is not particularly regulated where I am (we put it in ponds and septic systems), but it may be regulated where you are.
John
