Author Topic: PCB Where did I go wrong?  (Read 11823 times)
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
Re: PCB Where did I go wrong?
« Reply #50 on: February 11, 2017, 01:17:04 pm »
One thing I would do is connect the transformer to one of your empty spare boards and see what happens. If the PCB house made a boo boo in the fabrication, it would be evidenced by the transformer overheating with no parts inserted.
I would then add a pair of diodes, connect and test; then the other pair, connect and test and so on.
The following users thanked this post: Richard Crowley
Online Spuddevans
« Reply #51 on: February 11, 2017, 01:47:25 pm »
Try connecting just one of the secondary windings to the PCB (ie not the two windings in series, leave the other winding un-connected) and see if it still heats up.
Did you measure the AC current flowing through the PCB?
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #52 on: February 11, 2017, 05:49:21 pm »
On the photo of the diodes only board, I see only one input terminal block installed.  How are you connecting the transformer to the board?  Perhaps a photo showing the connections would be helpful.
-Pat
Offline rsjsouza
  • Eternally curious
« Reply #53 on: February 11, 2017, 07:54:35 pm »
That is a good point. If you are connecting both wires of the transformer to "AC1" they will be shorted according to your drawings. You should have both "AC1" and "AC2" populated to connect the transformer.
Offline goldfingerTopic starter
« Reply #54 on: February 11, 2017, 11:04:54 pm »
All,
Firstly want to say a big thank you to everyone who offered advice and help. I've found the issue there is a defect on some of the boards under neath near the ac entry with some bubbling now it's only very small but it looks like gnd plane might have defect to ac net. Which explains why it happens on entry! Thanks all really appreciate everyone's time and help.
Awesome!!! :)
Sent from my 486 IBM WIN 3.1x Desktop...
« Reply #55 on: February 11, 2017, 11:11:55 pm »
-Pat
Yeh I installed one and realized the tinned wire on the smaller transfomer was small enough gauge just to sit in hole mate snug to test so didn't bother
Offline neil t
« Reply #56 on: February 12, 2017, 12:36:58 am »
All,
Awesome!!! :)
Excellent, congratulations, who doesn't enjoy a good sluthing moment, I think there was a number of guys  trying to lead you to that conclusion. It seemed so obvious from this side. but highlights to all of us the need for due diligence when fault finding ie: the need to start from the source or origins and follow a logical path, as head banging as it can be the absolute thrill of finding a fault and subsequent satisfaction of gained knowledge. excellent stuff which is one of the reasons I joined this forum.
regards Neil :-+
« Reply #57 on: February 12, 2017, 12:39:51 am »
All,
Awesome!!! :)
regards Neil :-+
Very true Neil, and thanks for your help! As much as a pain in the butt it is/was at least I know now how to fix!!! :)
Thanks again to you and everyone else for their help and feedback!!!
Offline Cubdriver
  • Nixie addict
« Reply #58 on: February 12, 2017, 01:25:11 am »
Excellent!  Happy to hear that you've found the problem.   :-+
I hope you can correct the issue with a bit of exacto knife surgery.
-Pat
